01-20-2008, 01:03 PM | #1 |
ART max height
Hey all, I have been on the fence between springs or bags for my 64 C10. I want to lower it about 4/6 f/r but also would like to be able to tow an original mini (1800 lbs including aluminum dolly trailer).
I would like to know if I do run bags, and want to tow, what height can I raise the truck to get more tongue clearance when cresting speed bumps etc? Oh yeah, I was looking at all the Air ride bolt on stuff. Their strong arms with shockwaves and their 4 link kit...also with the Baer 2 inch drop spindles and brakes... It will be on 18's with 275 45 18 R and 255 40 18 F. Thanks
Semper Fi |
01-22-2008, 11:29 PM | #2 | |
Re: ART max height
nickle and dime |
01-23-2008, 06:10 AM | #3 |
Re: ART max height
You could use a RE-8 Slam or the 8"dia Firestone to get more lift. There will still be limits unless your shocks are also set up for extended travel.
I used 7"dia Firestone bags in place of coils & it worked fine towing my 18ft car hauler around. No tongue dragging issues except for on the worst of driveways (trailer dragged in the same spot when towing it w/a stock height truck).
01-23-2008, 07:20 AM | #4 |
Re: ART max height
being new and rather uneducated when it comes to the bags... What comes on the shockwave kit?
If I could raise it to what say a normal 4 inch drop would be then all is fine
Semper Fi |
01-23-2008, 08:21 AM | #5 | |
Re: ART max height
If I understand correctly, you want equal to 4" of rear drop when you have the truck raised-up or extended. How much drop are you looking for @ ride height?
01-23-2008, 08:40 AM | #6 |
Re: ART max height
Well to be honest, I would like a 4-5 inch drop up front and a 6-7 inch drop out back. From what I have seen of other peoples trucks.
Right now the front fender lip is at 32 inches and the rear is at 29 inches...Not really sure what is going on back there... so its hard to measure from what I have now. I would just like to raise the front an inch or two and the same for the rear should I want to hook a trailer up to it. Just for clearance issues.
Semper Fi |
01-23-2008, 10:44 AM | #7 | |
Re: ART max height
01-26-2008, 10:05 AM | #8 |
Re: ART max height
Yep but a 64 sitting on 18 inch murdoc III's from Budnik
Semper Fi |
01-26-2008, 10:41 AM | #9 |
Re: ART max height
Mine is 7~8" of rear drop & I just level it out (or just a tad higher) when I hook up the trailer. This is the best pic I have w/the trailer semi-loaded. It could get more rear height but the it would have severe rake front to back or the front would also have to come up killing the alignment.
I use the ECE hidden hitch w/a 'fixed' trailer jack on the front of the trailer & haven't had any serious problems that I didn't encounter in a non-lowered truck.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-26-2008 at 10:43 AM. |
01-26-2008, 10:44 AM | #10 |
Re: ART max height
Nice that looks like more weight right there than I would be towing. I feel much better now.
Looks like i will be going with the shockwaves front and rear with stong arms and their 4 link...$$$$ Got to eat more rice and hot dogs...
Semper Fi |
01-26-2008, 02:23 PM | #11 |
Re: ART max height
ShockWaves & the 4-link aren't necessary & add to the cost. But if that's what you want, sounds like a good plan.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-26-2008 at 02:23 PM. |
