Old 01-26-2008, 11:18 PM   #1
Firearmfiend
divorced t-case
I'm planning on converting my truck to diesel (see thread: http://67-72chevytrucks.com/vboard/s...d.php?t=275428 ) and I'm planning on mounting a rockwell 221 divorced t-case from a '66 K-10 with the install in preparation for conversion to 4wd at a later date. Any advice out there? I'm fully set up to fab a x-member for it, how does this sucker mount anyway?
Also, I'm planning on using the FGB52 front spring hanger setup from diy4x.com. Anyone have any experience with this setup or company?
Thanks ahead of time!
'70 C-10 Short/Fleet 350 In the family since new and more than 300K on the odometer!
Firearmfiend is offline   Reply With Quote
Old 01-27-2008, 03:20 AM   #2
abebummy26
abebummy26's Avatar
Re: divorced t-case
Everyone I have heard speak of Kert (fabricator) @ diy4x.com. Has very good things to say about him and the stuff he makes. Grendel is going to use them on his truck. here is his build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=240908
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 01-27-2008, 05:54 AM   #3
1969 GMC
1969 GMC's Avatar
Re: divorced t-case
If you must run the Rockwell T-case, make sure you go through it first. Definitely give it new seals even if it looks like it doesn't need it.
Then when you have it in the truck, keep a close eye on the gear oil level. These cases like to run the input bearing dry if you are low on lube, and bad things happen then.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-27-2008, 06:05 AM   #4
earl87gta
earl87gta's Avatar
Re: divorced t-case
I dont know about the divorced rocks i used a dodge devorced 205 and they mount from the top not the bottom so if there the same you may have to do a body lift to get them to fit. for a shifter I am making a cable shifter. I didnt like how the rockwell sounded like a jet engine taking off all the time.
One trouble that poeple with devorced cases have id they like to move fron to back may not be an isue with the rocke well if it uses and under the case crossmeber but the 205 under hard wheeling like to move so they say to build a brace of some type to go from the back bottom of the case to the frame.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 02-02-2008, 10:37 PM   #5
cobinder
Everything is work in progress
cobinder's Avatar
Re: divorced t-case
Why divorced? what tranny you using?
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 02-03-2008, 12:28 AM   #6
Firearmfiend
Re: divorced t-case
using a SM-420 2wd tranny
Old 02-03-2008, 03:05 AM   #7
earl87gta
earl87gta's Avatar
Re: divorced t-case
I like how the divorced case give you the ability to use somthing else later if you want if I ever get tiered of shifting my nv4500 I can cange to an auto wit out having to get adaptors to make it all work.
Earl
Old 02-03-2008, 09:15 AM   #8
Firearmfiend
Re: divorced t-case
I'm the same way, but let me know if you decide to get rid of that "junky" NV4500 anyway
but seriously, I also like the idea of equal length driveshafts, I've ALWAYS got a spare!
Old 02-10-2008, 06:22 PM   #9
earl87gta
earl87gta's Avatar
Re: divorced t-case
I that is one other plus you only have to have one spair when on the trailes.
I was going to go auto for a while but I just didnt want to use an 700r4 and I didnt like the idea of the 480le ECM .
Earl
