Air bags with a big block??
What rating of bag should I be running up front with a big block in my Suburban?
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's 1995 K2500 Burb as daily driver 350 with 193K miles 1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse |
Re: Air bags with a big block??
I don't think you need to worry so much about the rating, but the bag you decide to run. Slams will lift way before the "others" and not need 110 - 120 before it gets up. I always hear complaints about needing a lot of pressure before they lift, so run Slams!! 7's should be fine, but at that point it's your preference, clearance issues and how it will ride.
Others will chime in and give their opinion, it's a common question / discussion. |
![]() Join Date: Aug 2005
Mine=Burb+BBC+RE7's No issues. Lifts at around 40psi, Ride at 70.
Hey FF you running the same bags in the back?
Yes. RE7's all around. Rides nice.
Look at his build thread, it will be worth the hour it will take!
![]() If you have questions about yours, his will answer most that you have. Slams are built specifically for air ride suspension, where others are not! That's why they work so well. |
