Old 01-28-2008, 01:03 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hydroboost question.
Can I run hydro boost on my truck if I am already running a hydro assist steering? Seems like it would max out the stock chevy pump??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-28-2008, 08:51 PM   #2
shilo
shilo's Avatar
Re: Hydroboost question.
if i think what your asking is " can i have power brakes and steering off the same power steering pump?" then the answer is yes. thats the way its made to work. if its a hydro boost pump, booster, and maybe even steering box.
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 01-29-2008, 12:15 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
I have a west texas off road hydro assist on my cross over steering. My box came from them also the pump is just a standard chevy unit I was just wondering if the chevy hydroboost would be too much since I am already running a ram on there.
MEMBER #6377
Project "7DEUCE"
Old 01-29-2008, 02:03 AM   #4
pumpkin
pumpkin's Avatar
I run p.s. , hydroboost, and a 12000lb hydraulic winch off my gm ps pump.
pumpkin is offline   Reply With Quote
Old 01-29-2008, 03:39 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Thanks pumpkin thats what I wanted to hear....
MEMBER #6377
Project "7DEUCE"
Old 01-29-2008, 11:12 AM   #6
cobinder
Everything is work in progress
cobinder's Avatar
Thanks pumpkin ; ) LOL
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-30-2008, 08:12 AM   #7
duallyjams
duallyjams's Avatar
I've heard that ps pump off of a diesel works the best.The valve is different, its made for low rpm witch is what most people using hydro steer need.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-02-2008, 06:04 AM   #8
pumpkin
pumpkin's Avatar
From the research I've done the saginaw pumps are all basically the same. The difference is in the preasure releif, and flow gpm. The diesels just use a larger diameter pully to offset the low rpm of the diesel.
Old 02-02-2008, 12:08 PM   #9
qksilver
one thing to think about is using a P/S cooler........pressure shouldn't be a problem but heat will be, plus you will probably also need a reservoir
qksilver is offline   Reply With Quote
Old 02-20-2008, 04:10 AM   #10
Ironman97459
What year model hydro boost bolts right in for the 1st gen trucks? (72)
Ironman97459 is offline   Reply With Quote
Old 02-20-2008, 07:02 PM   #11
vtblazer
vtblazer's Avatar
Wouldn't a larger pulley make it turn slower yet?
vtblazer is offline   Reply With Quote
Old 02-20-2008, 09:44 PM   #12
pumpkin
pumpkin's Avatar
I don't think there is a bolt in. I took one from an 87 and made the firewall bracket fit, then redrilled a hole in the brake pedal, this took a couple of tries to get the feel and stroke right. Will be doing another one soon out of an 89 p.u.
Old 02-21-2008, 05:54 AM   #13
68K20 x Drill
MY diesel sub has a remote resevoir, but otherwise the pump looks the same.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 02-21-2008, 10:33 PM   #14
Yukon Jack
Yukon Jack's Avatar
Not a direct bolt in but here is a link to how I did the conversion.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
