![]() Join Date: Apr 2004
Panhard question
I’m in the process of plumbing my air bags on my ’72 blazer and I noticed that when its layed out the rear end is not centered. It’s much closer on the driver’s side. Will a shorter panhard bar correct this? If so, how do I know which one to buy?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Truck and auto performance nut
Re: Panhard question
you need an adjustable one. available thru most vendors.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Correct me if i'm wrong, but you want a longer bar, not a shorter one. The longer it is, the less movement you will get. Also, don't worry if your rearend is not centered when you're laid out. It shouldn't be. It should be setup so your all centered at ride height. Then as you move up or down from your ride height, you will get movement from center.
I looked up bars at Summit and a saw that they had about a dozen choices from $85 to $200. Any recommendations?
It's a little off at ride height, but it makes my tire kiss the inside of my fender when aired out.
are you looking for a weld on or bolt on application?
for bolt on, I would recommend to go to earlyclassic.com and check out the super track bar.
What you really need is a "Watts link". A panhard bar will always be off-center at some point in the suspension travel of a 'bagged vehicle. You can get an adjustable bar, but that only lets you decide "where" it is right. The more travel you have in your suspension, the greater the effect.
A sliding, wish-bone type 3rd link will work too. It depends upon your fab skills and the available space under your truck, but you could do either. |
Tot Roddin'
ECE... all the way!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I'm not sure a watts link would work with my gas tank in the middle.
67-72 parts collector,…
![]() Join Date: Nov 2002
I'm surprised it's closer on the driver's side when "air'd out". I would think it would shift to the passenger side. Try the Super Track Bar from ECE. It's longer than the stock bar (for less movement),... and is a bolt on. But you will still get movement. And the reaseon it's longer,... is because it attaches to the passenger side trailing arm.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-28-2008 at 07:23 AM. |
#12 | |
Hollister, CA.
![]() Join Date: Sep 2006
Here is what a basic one looks like.... - - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I am seriously rethinkin the panhard in mine. I am leaning towards the watts also.
Does anyone sell a kit for these or would I need to fab everything myself?
#15 |
Surviving, one day at a time!
Check out KPComponants.com they might have one for your application.
#16 | |
#17 | |||
Hollister, CA.
Click on the build link to see more pics - -
#18 |
www.speedwaymotors has one for like 70 bucks. It goes off the top of the axle. You could make your own diff. bracket though.
#19 |
That one from speedway might be goot on a 9" I dont know about mounting that top bracket on GM diff where the center section is cast. I'd take some mesurements and call KP to see if it would fit, Clint seems to know his s#!t.
