Old 01-28-2008, 05:02 AM   #1
TravisH
TravisH's Avatar
Parking brake - what are my options?
Truck originally came with a granny 4 speed and had the brake on the tail end of the transmission. I've got the pedal and cables/brackets are no problem but I haven't a clue what I need to do on the drums to hook it up. Can I drill through the backing plate and make these work or do I need new parts?
edit.. this is the passenger side so right = rear of truck
TravisH is offline   Reply With Quote
Old 01-28-2008, 06:22 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Parking brake - what are my options?
I'd be finding a pair of backing plates that already have the parking brake mechanism. That way you'd know what went where and that it was all set.
Member Nr. 2770
Old 01-28-2008, 04:53 PM   #3
TravisH
TravisH's Avatar
so are the plates pretty much interchangeable for the next 15 years or do I need 67-72 specific?
Old 01-29-2008, 02:38 AM   #4
clay68c10
clay68c10's Avatar
They all look similar, but I'd do some junkyard searching to verify before you jump in and buy anything.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-29-2008, 02:50 AM   #5
whatnow123
whatnow123's Avatar
I have a set of backing platesI took off my truck that has the ebrake hook up of you want them. Pay for shipping and they are yours.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-29-2008, 11:05 AM   #6
TravisH
TravisH's Avatar
I might take you up on that whatnow
Looking at the plates I can't imagine theres any difference other than the hole but I'm probably short the pivot arm. I'm going to pull off the drum after my paint dries a little
