Timing and ignition question
I've been considering putting gear-drive on my 350. Some people tell me its not a good idea others say it is, but no one gives me actual reasons why. What are the pros and cons to gear drive? Will it be worth it in the long run? As far as I know its the same as chain driven timing and I really like the sound that gear drive makes.
Also, how can I convert my stock ignition to HEI? Is it hard to do?
__________________________________ 1969 GMC 3/4 Ton 4x4 - 350 4-Speed 2004 GMC Sierra 1500 4x4 - 5.3L Auto |
its all about the +6 inches
Re: Timing and ignition question
I've always felt it was kinda poser-ish... like the early pro-street stuff, where there wasn't enough engine to spin the huge tires, or more recently, the import craze, where they'd add a butt load of guages and stickers and think they had a hot rod.
Blower whine should mean blower... not I wanna sound like I have a blower. |
I have seen them work for some folks but, most of the time they are nothing but a headache and fail leaving the owner with expensive repairs....
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 01-29-2008 at 11:14 AM. |
Truck and auto performance nut
some people like the sound of a gear drive...that's why they make both "quiet" and "noisy" versions. not quite the same as "blower wine".
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
I'm not looking for a blower whine, the truck is not by any means a "hot rod" or drag truck, its a workhorse. Its getting a plow when its done, I just want to know if the gear drive is worth it. If not then I won't waste my money and stick with chain drive.
I don't think there is any performance advantages... esp at the non-hot rod performance levels.
I didn't mean to imply that YOU were a poser or a fake. |
Parts and more parts
So ---Tell US why you want a gear drive. What is it, about the gear drive intices you to spend the money on it? I have seen some guys with these and the noisy ones are just plain irritating and the longevity is not that good. Go with a quality gear set and chain and get the attention from the HP that you build into you motor, not the noise that you make.
my understanding is that a gear drive holds timing better...since there's no stretching of a chain going on.
![]() Join Date: Dec 2006
For a race car it might be some advantage,I don't know. For a work truck FORGET IT!!!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
I have a radical idea!
A truck engine will never see enough RPM to ever need the supposed more consistant timing advantages of a gear drive. In fact, most serious race engine builders don't even use them anymore. They use either a high-end true roller timing chain or Jesel or other brand belt drive. The dual idler gear drives for SBC's wear out really fast, and would begin to effect timing issues on a regularly driven engine WAYYY before even a stock timing set ever would...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Truck'n the alcan
If you want something that will last the life of the motor go with a "good" roller chain setup, and to keep the timing dead on advance the cam 2 degrees when you install it. That way when the chain stretchs you'll be in good shape.
68 GMC 4x4 71 C20 Custom Deluxe 83 1/2 ton conversion van Last edited by Alaskan; 01-29-2008 at 04:55 PM. |
On the two engines I've rebuilt my machine shop guy has ordered me a slightly wider than stock timing set. Maybe somebody can help you with a specific part number. The stock ones usually make it 100,000 miles. So assuming this wider one is better, how long do you expect this truck to last? Mine is NOT a daily driver. Since the spring of 1994 I've put 27,000 miles on the truck. At the rate I'm going I should expect to have to deal with a timing chain in 2050, 42 years from now.
I think you'll be fine with a plain old chain and sprocket set. Wait. I did the math wrong. I have 27,000 on the truck, only 2000 on the engine. Add another 14 years on to my figures. I expect to do a chain in 2064, I'll be 96 years old then.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#13 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Hot Rod magazine did an interesting test on gear drives and found no horsepower gains...and very little with timing stability. The gear drive is really for situations where the valvetrain is really being worked hard - high spring pressures, etc.
A good Cloyes Tru-Roller isn't going to have any trouble with any engine that's streetable ![]() |
#15 |
The reason why I was considering it is because of durability and chain stretching, but if they really have no improvement with a gear drive then I'll stick with chain and sprocket. Thanks for all the input.
