Old 01-30-2008, 01:07 AM   #26
1LoC10
Insert Title Here
1LoC10's Avatar
Re: 84 with a Dropmember
looks awesome man... i really got to move out there by you...lol
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 01-30-2008, 11:57 AM   #27
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by boxrodz View Post
The Dropmember is a nice piece (like everyone says).
Thanks for showcasing it here.
I've followed your thread (http://67-72chevytrucks.com/vboard/s...d.php?t=201898) in the Suspension forum as well as some of the other's Dropmember threads. Most of the information provided centers around the 67-72 crowd. If I may, would you field a few questions about the Dropmember in the 73-87 trucks?
1) I understand that the Dropmember is designed with the use of the Strong Arms LCA, although it will also work with the stock LCA with no modifications necessary. Is it correct to assume that the air bag mounting plates are parallel to each other at ride height? Is this also the case if one uses the stock LCA with, say, a plate (or cup) for the lower air mount? What would the distance between the two parallel mounting surfaces be? I'm wondering if a 224C (instead of a RE7) would maintain the parallel mounting surfaces of the bag's ride height at ~5 1/4".
The air bag mounting plates are parallel at ride height. Stock arms work great,and I also can supply a bolt-on plate to be used for the lower bag mount. An ART lower arm will allow the truck to set approx. 1 inch lower than the factory lower arm and PB plate combo (when using a Slam bag). The Firestone bag will bolt-up and work just fine... and allows the truck to rest approx. .5" lower when deflated.
2) Although the Dropmember relocates the engine a ‘couple of inches’ forward and upward, no modifications are needed to the firewall and tunnel for clearance. Would this be accurate for a SBC as well as a Gen III?
This is accurate with a SBC and as for the GenIII... I have not installedone in the square body, but Hill's Hot Rods' has and did not mention any firewall clearance issues... they're even running the coil-pack covers on the motor (it's in Jason's Hard-top Blazer).
3) Is it possible to retain the geometry of the R&P steering, if the stock outer tie rod ends are shortened and re-threaded? You mentioned in your thread, that both the outer tie rod ends and the R&P, had to be shortened. I'm wondering for these trucks, if only the outer tie rod ends can be shortened without shortening the R&P.
The outer tie-rod end of the rack needs to be shortened... the actual outer tie-rod end used on the kit is a chromoly heim joint with associated hardware. Factory C-10 outer tie-rod end will not work.
BTW, you mentioned that the tracking of the Dropmember setup is narrower where the rotor face to rotor face width on the regular Dropmember is 60". From my measurements, the stock width is ~ 61 5/8” from outer surface of the rotors.
Well... one issue I have found when measuring trac-width is that different numbers can be derived by measuring at different spots, and different height of the suspension travel...these trucks do have some scrub built into the factory design that can skew measurements if not taken from the same place at the same height etc. What I have since done to correct this and give an accurate measurement of trac-width difference is to measure the distance between the inner pivot centers of the lower control arm (bushings) and then compare. The Dropmember is narrower by approx. 3"give or take.
Finally, one last request:
At ride height, do you know how high the front fender lip is from the ground on the 84? What is the size of the front wheels, drop spindles and front bags?
The front wheel is a 20x8.5 and has a 5.25" backspacing.The tire is a 255 35 20... I willhave to measure the wheel lip height when the front end gets reassembled... everything is at the powdercoaters.
Any information you may provide is appreciated.
Thank you.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-03-2008, 02:16 PM   #28
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Nate,
Thank you taking time out to address my questions.
I haven't quite graduated 'down' to the 'worm digger' stance, yet. Right now, I'm more interested in low stance and drivability at ride height. I've been pushing some numbers around on paper and have a possible drop combination in mind for the front. It'll required more than the typical drop spindle and dropped springs (or bags). It seems like one benefit of the Dropmember is that it'll maintain the suspension geometry of the front end. A much lower ride height with more ground clearance over the stock is a plus. And, a lower drop (in the future) using the Dropmember is possible.
I was just wondering 'bout an alternative to the heim joint for the outer tie rod end. I was curious to see if there is a stock outer tie rod that would mate between the R&P unit and the spindle... I've seen some of the other aftermarkets front members with R&P use what looks like a stock tie rod ends for some of the 60s Chevies and rods. I don't know if the length and size is comparable... My guess is probably not.
I hadn't considered the scrub, but I understand what you're saying. I'm curious now on what specs a good alignment shop will use to set up the front at ride height. Hmmm...
Given a narrower track in front with the Dropmember, now have me wondering what the minimum BS one can go with and still avoid rubbing the inner fender lipp with a couple of inches tucked (at ride height).
I'll stay tune for the wheel lip height (and, of course mo' pics) when you start reassembling everything. Should look purrrty.
Thanks again.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 02-10-2008, 12:28 PM   #29
PBFAB.COM
PBFAB.COM's Avatar
Got the thing back on the ground and snapped a few teaser pics...
The truck is not completely aired out in the pics... about an inch to go. I need to remove a couple brackets on the frame that hang down below the frame's scrub line. Also, don't know why, but every single one of these square bodies has a funky frame bend (looks like it's tweaked) on the driver's side below the cab. A little heat and a special dolly I made flatten it right out... just haven't gotten there yet!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-10-2008, 12:29 PM   #30
PBFAB.COM
PBFAB.COM's Avatar
few more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-10-2008, 01:03 PM   #31
lolife99
67-72 parts collector,…
lolife99's Avatar
Let me know when you get prices together for the rear kit. Also what are the wheel specs that will work on the rear? Looks like a 22/20 combo. Thanks for keeping us updated.
Keith
Convert to disc brakes.
Old 02-10-2008, 01:06 PM   #32
1LoC10
Insert Title Here
1LoC10's Avatar
sweet
BOBBY
_69 SWB_
Old 02-11-2008, 01:14 AM   #33
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Originally Posted by porterbuilt View Post
...Also, don't know why, but every single one of these square bodies has a funky frame bend (looks like it's tweaked) on the driver's side below the cab. A little heat and a special dolly I made flatten it right out...
That tweak is to get the frame away from the catalytic converter. Most people panic when they first see it. I did! At least all the 1/2 and 3/4 tons have it...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 02-11-2008, 01:18 AM   #34
PBFAB.COM
PBFAB.COM's Avatar
First time I saw it... I thought that maybe the truck had been pulled out of a ditch with a hook there or something!
After seeing a few more... I realized it had to be a factory deal. Never paid attention to seeif it was for cat clearance! Thanks for the input.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2008, 04:01 AM   #35
copperchevy
copperchevy's Avatar
Any underhood pics????
Mexican
copperchevy is offline   Reply With Quote
Old 02-11-2008, 02:12 PM   #36
Dinos63
chevy only
Dinos63's Avatar
nate looks killer, i love the back half ,i will have to stop by and check it out.nice job as usual and those are 22 on the front right.
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-11-2008, 02:16 PM   #37
PBFAB.COM
PBFAB.COM's Avatar
20's up front... same size as your 78.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-11-2008, 02:30 PM   #38
Dinos63
chevy only
Dinos63's Avatar
are those his wheels? or the west coast trucks
Old 02-11-2008, 02:51 PM   #39
PBFAB.COM
PBFAB.COM's Avatar
These are his... same style wheel though. West Coast has 22's all the way around.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-12-2008, 12:26 AM   #40
chevyrestoguy
chevyrestoguy's Avatar
I love the way that thing sits. It's refreshing to see one slammed and not have the camber all whacked out.
chevyrestoguy is offline   Reply With Quote
Old 02-12-2008, 12:42 PM   #41
SCOTI
SCOTI's Avatar
Nate,
I can't believe I missed this thread. Is that the same truck we pushed in/out of the shop when Keith & I were out there?
What's the rear suspension going to be?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-12-2008, 01:40 PM   #42
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by SCOTI View Post
Nate,
That's the truck... but it didn't feel like you "helped" push it!
At least you didn't try to sever the fingers off my left hand!
The rear features a bolt-on notch that'll lay the frame on a 30" tire, bolt-on parallel four-link with panhard, sleeved bags, and some pretty blue Monroe shocks. I will get some more pics up of the rear over the next couple/few weeks. I have to take it apart and finish weld a couple spots, have it powdercoated, and then reinstall everything.
I will also include some engine compartment pics... good news for you guys wanting to keep the factory A/C and heater box... it fits with a 27" tall tire. You can slide a piece of paper between the tire and the blower motor when it's fully deflated. I would recommend a new blower motor that is a bit shorter than the factory one, or one can always section the box a little... not much.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-12-2008, 08:39 PM   #43
n2billet
Village Idiot....
n2billet's Avatar
I'll never live down the "finger incident" will I?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 02-13-2008, 01:30 PM   #44
PBFAB.COM
PBFAB.COM's Avatar
Maybe once the scars go away!
and not just the physical ones!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-14-2008, 06:20 PM   #45
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Are there any clearance issues on the drivers side with the power brakes, brake lines and such?
GMBowtie79 is offline   Reply With Quote
Old 02-14-2008, 11:03 PM   #46
mrenj23
mrenj23's Avatar
Those dropmembers are crazy. I'm not even finished with my truck yet and I'm thinking about redoing it...First I need to save up my lunch money so I can get one.
mrenj23 is offline   Reply With Quote
Old 02-15-2008, 12:10 AM   #47
baggedcten
86 C10
baggedcten's Avatar
are you running a parallel four link on the rear?
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 02-22-2008, 11:44 AM   #48
VROD383
VROD383's Avatar
Nate,
whats the price for the dm, ART a-arms and slam airbags.
VROD383 is offline   Reply With Quote
Old 02-22-2008, 12:18 PM   #49
PBFAB.COM
PBFAB.COM's Avatar
The brake lines for the front calipers need to be moved a little bit for the rack and pinion c-notch... but as far as the booster/master cylinder clearance, there are no issues...with a 27" tall tire. I don't think a 29" will have any issues either, I will check and get some good pics for reference.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-22-2008, 12:19 PM   #50
PBFAB.COM
PBFAB.COM's Avatar
Yep...its a parallel four-link (the whole thing bolts in... even the notch) and it's running a panhard bar. Through 7.5" of travel the axle shifts a total of 1/4 inch laterally.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
