Old 01-16-2003, 12:04 AM   #1
1FaastC10
1FaastC10's Avatar
manual box vs PS box (73-87)
i have both a manual box, and a PS box for my 82 C10. i'm thinking about using the manual box to save weight, as i will be lightening the front end as much as i canto improve the balance. i have both boxes, and both pitman arms. are there any other differences in the steering linkages i should be aware of. TIA
1FaastC10 is offline   Reply With Quote
Old 01-16-2003, 01:24 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Nope, if you have the pitman arm that should be the only diff. That is all I swapped and it has been running fine for over 10 years. If you like PS, you are going to HATE manual, especially if you have to parallel park. You basically are only saving the weight from the PS pump, the boxes aren't that much different.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-16-2003, 04:59 PM   #3
1FaastC10
1FaastC10's Avatar
saving the weight of ther PS pump is better than not saving any at all...
i've got both boxes side by side in the garage, the manual box is considerably smaller and lighter. both are from 1982 C10s, maybe you've got a different box since yours is older?
Old 01-16-2003, 06:22 PM   #4
Captkaos
Captkaos's Avatar
Mine is the variable ratio box off of an '86 truck, same as yours.
It's like 4lbs. diff for the box and about 6lbs for full pump, or there abouts, right. Granted, every 10lbs is about .5hp, and 200lbs is about 0.1 second or 10hp, but it wasn't worth it to me. But, weight is weight....
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-16-2003, 06:28 PM   #5
Captkaos
Captkaos's Avatar
BTW, shove the motor back as far as you can. This makes a large impact on weight balance/transfer.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-17-2003, 07:07 PM   #6
1FaastC10
1FaastC10's Avatar
does anyone know exactly how far back i can set it? as of right now, my cab is in the garage on the floor, the crossmember is in the shed, the motor mounts in the attic, the engine under the bench, and the frame sitting in the yard... makes it hard to check for clearance.
Old 01-17-2003, 09:07 PM   #7
Captkaos
Captkaos's Avatar
Are you planning on running a Stock large HEI distributor and not cut the firewall? The answer is none.
You will need to modify the firewall to make any good gains, although moving 600lbs backward and inch will improve it. I wouldn't go to the trouble unless you are thinking or more than a couple of inches. What is the final intention?
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-17-2003, 10:52 PM   #8
1FaastC10
1FaastC10's Avatar
Chris, the overall goal is to take as much weight off of the front end as possible in order to improve the balance of the truck. a better balanced truck is a better handling truck, right? and if i cant get it to handle like that, i can always go drag truck with it...
Old 01-18-2003, 06:39 AM   #9
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Drag truck it Jeremy.
Having manual steering w/ a manual steering box is 10x better then having manual steering with a PS box.
Sucks arse....
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 01-18-2003, 12:44 PM   #10
1FaastC10
1FaastC10's Avatar
i'd like to be able to play in the twisties too Paul. moving that much weight back off of the nose should also make it do better at the dragstrip. dual purpose!
Old 01-19-2003, 03:25 AM   #11
Big Paul
Big Paul's Avatar
Fuel cell in the back, relocated battery, no a/c equipment. Maybe a glass hood too.
That oughta help.
~Paul~
Old 01-19-2003, 03:47 PM   #12
Captkaos
Captkaos's Avatar
I know exactly what you are talking about Jeremy. I am setting mine up for turns. I went with the fiberglass tilt, and am removing all I can also. Its that I have driven mine for about 3 years with a manual box and just 275/60/15's and it is a pain in the but to turn, plus the PS box is a quicker ratio, and I am planning on running wider than 275's, so that would stink with the manual.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-19-2003, 09:21 PM   #13
1FaastC10
1FaastC10's Avatar
glass hood is a definite, as are inner fenders, possibly fenders too. there's a guy about 100mi from here that makes glass hoods, real good quality stuff, and cheaper than anybody else too. Chris, and ideas on where i might be able to find a quicker ratio manual box?
Old 01-21-2003, 06:34 PM   #14
Captkaos
Captkaos's Avatar
I don't know of any worm gear manual boxes that are quick. Your only other hope is to use a rack and Pinion.... $$$$
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-21-2003, 07:04 PM   #15
1FaastC10
1FaastC10's Avatar
$$$$ and lighter to boot
Old 01-21-2003, 07:14 PM   #16
Captkaos
Captkaos's Avatar
Hey, since we're spending your money how about a custom chassis with R&P, 12" disc with B-body spindles and a 4 link to boot!! http://www.jimmeyerracing.com Jim Meyers has a complete chassis he will build for you for only $8000!!!
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-22-2003, 01:33 AM   #17
1FaastC10
1FaastC10's Avatar
no thanks, im a "do it yourselfer" i'll farm the little stuff out, but it will be done my way, and i'll assmeble it. then when something doesnt turn out as planned, its my fault.
Old 01-22-2003, 03:57 PM   #18
Captkaos
Captkaos's Avatar
Yeah, my thoughts exactly. For $8000, I could buy another freakin' truck!.. I am wanting to convince my brother to build a frame jig when he gets his shop finished...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
