Old 01-30-2008, 10:56 AM   #1
prg machine
prg machine's Avatar
installing ignition lock
can someone explain how to put this back in the housing...?? I sure would appreciate it.
prg machine is offline   Reply With Quote
Old 01-30-2008, 01:24 PM   #2
corn
Re: installing ignition lock
I cant remember but I think you have to stick a paper clip in the little hole before you put the ring back on. hopefully someone will chime in & help...
corn is offline   Reply With Quote
Old 01-30-2008, 01:29 PM   #3
69C10@16
The ignition cylinder slides right in. Make sure you took the old one out first
Anyways, on a more serious note, Put the key in the new cylinder (or if you're just puttin the old one back then that one) and start it where the key would be in the acc position (turned counterclockwise one notch from off) or maybe just a bit past that. Push it into the switch and turn it clockwise. It should snap right in. Good luck!
69C10@16 is offline   Reply With Quote
Old 01-30-2008, 10:59 PM   #4
prg machine
I like that signature line............. i payed 1800 for the basket case and 10 times that at least now.... and still not on the road!!!
