Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-20-2008, 08:16 AM   #26
SCOTI
SCOTI's Avatar
Re: Intros and set up..
Originally Posted by CyanJaguar View Post
where are you? Im looking for some help with my build.
Garland/Rowlett area.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-20-2008, 12:34 PM   #27
Super73
Super73's Avatar
I do have a tailgate.. Look at the earlier passes, it's up. We put it down after 7-8 passes.
Move the batterey, move the tank, get some tires and front spring is the one I would play with first..
Also, as lame as it sounds, short shift in to second.
Super73 is offline   Reply With Quote
Old 01-29-2008, 04:58 AM   #28
ElkyRacer
Hey Super73, are you using a 4L80E from a LS motor? Or is it from a conventional SBC? Ive got a 5.3 that Im putting a 4L80E from a 97 behind. Im going to have to buy another converter as the one Ive got is for a 6.5 TD, and was wondering about your 3200.
Kyle
ElkyRacer is offline   Reply With Quote
Old 01-29-2008, 11:40 AM   #29
Super73
Super73's Avatar
My 3,200 is spoken for. The 91-present use the same verter but have a slightly different bolt patern on the bell housing to block. Only 1 bolt hole is mis-aligned. That is how I am running mine right now.
Today had both good and bad in it. Got my rear draglites in yesterday so I had the MT ET Street 30x13.50's a buddy had mounted. Had to clearence a little more of the bed (tubs are out) to fit the inside and I had to get rid of the e-brake cable.
Bummer part was some how one of the driver shank lugs striped. When I went to take the wheels back off it snaped one wheel stud.. I guess it's better that way so I can pull the axles and put some longer ARP studs in it.
Also pulled the heater box, removed the front bumper and trimed the bumper horns off with the plasma cutter. I think I'm gonna fab up a roll pan for the front.
I need to convert over to a manual brake set up. Any one know of a good dual master that I can find in the local bone yards?
Also thinking of swaping this vega steering box I have in over the power set up. Just need a pitman arm and work a steering shaft.
Old 01-30-2008, 12:05 PM   #30
Super73
Super73's Avatar
New tires hooked great on my small test pull today. Couldn't spin them out of the hole with the 3,200 verter. We'll see what happens with the 4,400..
Old 01-31-2008, 09:51 PM   #31
djracer
djracer's Avatar
My setup would be too much typing so Liz moved my build thread here. I have had a few folks read the entire thread lately be fore warned it is LONG! The link is in my Sig. I'm helping a friend bag an 03 Silverado right know but I will be back on the drag truck soon!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-01-2008, 09:27 AM   #32
scatesracing
Machinist
scatesracing's Avatar
very very long ..... but well worth the read
scatesracing is offline   Reply With Quote
Old 02-01-2008, 09:33 AM   #33
djracer
djracer's Avatar
Thanks I'll be adding to it pretty soon!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-01-2008, 09:58 AM   #34
scatesracing
Machinist
Hey guys. and gals ........ Im still pumped about our own section in the foums.................. a little about my truck..........
1969 chevy swb
.060 over 350
comp cam
harland sharp rockers
hpt pistons
cast crank
2 bolt main
441 heads/ with a lot of work done to them
350 turbo tranny with brake
5300 stall
NX nitrous kit
5.83 gears moser 33spline axles and full spool
s&w coilovers
best pass 12.51 at 104 mph (horrible pass horable day.. but that is for another post some other day)
Old 02-01-2008, 10:30 AM   #35
djracer
djracer's Avatar
sweet ride I'll be glad when mine is pretty and shiney!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-01-2008, 12:01 PM   #36
scatesracing
Machinist
not as pretty as it once was.......... look at the second pic left of the back window above the bed rail... thats a hole ripped in the cab and you will also notice the rear quarter is rolled under..... the weekend before that pic was taken i took a friend for a ride and all hell broke lose. I had it up on the converter on the break....when i let go it blew the tires off and started wheel hopping pretty bad when i shifted to sec. it sheared the wheel studs and the wheel came off and just about ripped the bed off .. it pulled three of the bolts through the frame ripped the fuel lines off and the nitrous line . there is a scrach at the top edge of the back window... thats how high the bed went.... it was a hell of a ride.....
Old 02-01-2008, 12:24 PM   #37
71Dragtruck
71Dragtruck's Avatar
Hey scates what size are you back tires and rims? Just wondering if they are the same as I'm switching to.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 02-01-2008, 12:26 PM   #38
djracer
djracer's Avatar
that sucks I'm glad mine didn't get too crazy when I left with a 250 shot and the panhard bar bracket broke off!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-01-2008, 12:27 PM   #39
scatesracing
Machinist
31x14.5 the wheels are 12" with a 4" back space
Old 02-01-2008, 12:30 PM   #40
scatesracing
Machinist
I didnt even spray it.... I think the lugs were lose.......................... I bet that was a fun ride though.. Did it go straight??
Old 02-01-2008, 12:34 PM   #41
71Dragtruck
Thanks, how much room do you have between the tire and frame? Just wondering, I'm going to try 31x16.5's on my 12" rim tucked in the fenderwell like yours and hoping it'll all fit, mine is mini tubed about 1 to 3/4" from the frame. Nice truck by the way.
Sponsored by:
Hard Candy Customs
Old 02-01-2008, 12:38 PM   #42
djracer
djracer's Avatar
I felt something go wrong when I let go of the button and lifted! I drove it to the turn off and onto the return road but I could hear something rubbing after I made the turn off. I took two straps and pulled it back to center and eased it back to the trailer.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-02-2008, 09:05 AM   #43
scatesracing
Machinist
I think your going to need a little more offset than I have. There is a least 6" to the frame on mine. The truck is stored an hour and a half away at my father inlaws farm for the winter. ill be out there this weekend i will look for sure................. this might help. My friends truck has 29x18.5 on 14" rims . and it dosnt rub the frame
Old 02-02-2008, 11:21 AM   #44
71Dragtruck
Thanks, my rim's are 15x12 with 7.5" back space. Right now I run 29x14.5 tire with a stock width rear end, I'm going to a narrowed 9" and lowering the rear so the tires tuck up a bit. I want them to sit in as much as yours do, the rear end is just parts right now and has to be built so I have the advantage of making it whatever width I need as long as there is room for the tire. I'm pretty sure I'll have room for a 31x16.5 tire but just want to double check before I buy tires and have them mounted, If I can't tuck them in I'll go to a 14.5 then instead, main concern is clearing the outer part of the inner where it sticks in a bit to joint to the fenderwell. I don't want it to rub the tire.
Sponsored by:
Hard Candy Customs
