![]() Join Date: Apr 2004
Removing coil springs.
Can you pull the front coil springs out of a truck with out using a jack? I’ve always used a jack and dropped the LC A slowly so the spring wont go crazy, but I can find a yard that will let me bring a jack (safety issue). They told me to just use a breaker bar. I didn’t think that sounded too safe. Suggestions? I was looking for newer ‘73+ control arms for my blazer.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Active Member
![]() Join Date: Jul 2007
Re: Removing coil springs.
I've got a set of these that I've used on other vehicles. Not sure where I got them, but H.F. has them also...
http://www.harborfreight.com/cpi/cta...temnumber=3980 |
The coils on these trucks don't stretch very much. You could take the lower control arm loose & stand back if you had to. You can usually find a jack in the trunks of cars in these pull it yourself lots. You could raise the truck with one of their A-frames with chain hoist & set the lower arm down on a wheel or something.
#4 | |
Active Member
This is for informational purposes only. If you try it it's at your own risk... (have to insert this in here. With all the lawsuits these days you never know who might see this and claim an injury... ![]() |
