Old 01-30-2008, 01:08 PM   #1
LEEVON
Moderator
LEEVON's Avatar
Looking for '87 TCC wiring diagram
Like the title says, I'm looking for a wiring diagram for an '87 1/2 ton, specifically the torque converter clutch from a 700R4 to the ECM. Why? I am swapping my TH400 for a 700R4 and want to wire the lock-up function to the ECM like factory. Thanks.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-30-2008, 01:16 PM   #2
krazy10
Re: Looking for '87 TCC wiring diagram
try these guys
http://www.bowtieoverdrives.com/index.shtml
when i put the 350tbi and 700r4 in my s10 they helped me out. i used a switch to lock mine up though..
krazy10 is offline   Reply With Quote
Old 02-02-2008, 12:23 PM   #3
LEEVON
Moderator
LEEVON's Avatar
Thanks krazy10. I am familiar with the vacuum-controlled converter lock-up but I guess I just like doing things the hard way by going with the factory set-up.
So I found a wiring diagram and the tcc solenoid has one wire going directly to the ECM and the other to a "RAWL Diode Module". Does anybody know what this is? I am thinking it is just the brake cancel / cruise switch.
Here is the factory ECM to TCC wiring. Simple, just need the right prom chip, a wire to the ECM, and the other to the "RAWL Diode Module". Anybody?
