pics of stock wheels
Anyone have pics of stock wheels and hubcaps. Just wanna make sure thats the route I want to go. Even though I not even close to the end of my project.
![]() Join Date: Aug 2007
Re: pics of stock wheels
Nice truck!! Hope the build is going well. Would you be interested in selling your center caps? I have stock 67 long bed that is going to be my sons and it will be some time before anything will get done.. They are shot on this truck.. Thanks, Mike
Off topic, but I gotta ask... What did you do to the steel bed floor to make it so slick? Filler?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
![]() Join Date: Dec 2006
Here's a few. The first is a 3/4 ton 4 X 4, the second is the 2 wheel drive 3/4 ton, and the last is a Cheyenne 10 "full wheel cover" option.
Active Member
Here's what mine look like.
TILT COLUMN GURU
Here,s the C10 King's farm truck and his black 72.
chevy runs deep
more pics PLZ
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
I hammered out the dents. Had it blasted then started blocking it down with filler. I cut blocks out of wood to fit the contour of the ribs. I then sprayed it with filler primer and sanded it several times... The filler isn't as thick as it looks. I got the floor pretty straight with the hammer... A big hammer. I have over a hundred hours on the floor though. But working on the truck keeps me from getting into trouble!
i just love them all.
I have a radical idea!
Here's some I have saved.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
