Old 01-14-2003, 06:27 PM   #1
tracy
steering prob
OK. WHEN I TURN ALL THE WAY TO THE RIGHT MY DRIVERS SIDE TIRE RUBS MY PITMAN ARM WHERE IT MEETS THE FRONT DRAG LINK. MY TRUCK HAS A 4 INCH LIFT AND 33 X 12.50 BFG'S ON IT. IS THERE ANY WAY I CAN ADJUST THIS OUT. WOULD A DROP PITMAN HELP?IF SO, HOW?
72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot!
tracy is offline   Reply With Quote
Old 01-14-2003, 06:28 PM   #2
tracy
OH YEAH THIS ISN'T MY 3/4 TON. IT IS A 1/2 TON SHORTY
Old 01-14-2003, 07:57 PM   #3
tracy
anyone?
Old 01-17-2003, 02:25 AM   #4
tracy
I cant believe no one has had this problem
Old 01-17-2003, 02:29 AM   #5
Blaze69
Blaze69's Avatar
What year is it?
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock.
The front end disc swap is finally complete
2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out.
Blaze69 is offline   Reply With Quote
Old 01-17-2003, 11:10 AM   #6
Mike C
Mike C's Avatar
Get rid of the 7" or 8" wheels you have and get some 10's. Or if you have 8's with 4" or more backspacing, go to an 8" wheel with 3.5" bs. You can get away with 4" on the 10's. Wheel fitment is a science, or occasionally blind luck... My 33 14.5 rubbed on mine when I had 8" wheels with 3.5" bs, but the 35 14.5 did not with the 10" 3.5" bs wheels I have now. I got rid of the crappy bias tires and run 35 12.5 BFG MT's now. The drop arm will not solve your problem.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-17-2003, 02:05 PM   #7
tracy
thats probably it. I have the stock rally style with 33/12.5 mud terrains. Are there any cheap stock style that would help.......backspacing wise?
Old 01-17-2003, 02:05 PM   #8
tracy
oh and it is a 1970
Old 01-17-2003, 09:52 PM   #9
Blaze69
Blaze69's Avatar
Hey Tracy,
You say that you have the stock rims on still? What size are they? If they are 8's then the tire has to look pretty funny mounted to them. 12.5's are going to buldge out alot on those skinny rims. Sounds as though the rubbing may only be the smaller of the problem......
