Old 02-06-2008, 03:24 AM   #1
68 short step
Re: project INCREDIBLE HULK
Originally Posted by 6T9GMC View Post
Hey, I Know When You Weld In The Patch Panels You Spot Weld And Keep Going In Different Areas, After Your Done Grinding It Down Smooth What Is The Inside Supposed To Look Like And Do You Grind It Down And Make It Smooth Too, Or Just Leave It?
depends on if that spot will ever be seen....in most cases the backside wont be visable, so the weld isnt ground down...but if it will be visable, ill grind it down...
on this truck, its gonna be nice from under it as well as from above, so the underside welds will be ground down and the underside will be bodyworked, too.
68 short step is offline   Reply With Quote
Old 02-06-2008, 05:02 AM   #2
6T9GMC
6T9GMC's Avatar
Thumbs up Re: project INCREDIBLE HULK
Thanks. It's Looking Good!
6T9GMC is offline   Reply With Quote
