Old 01-30-2008, 10:25 AM   #1
tx71smallblock
tx71smallblock's Avatar
High idle speed
My truck is running fine but it idels almost at 1200 rpm. the electric choke is not hooked up and the timing is almost at 18* btdc. whats going on?
really need some help with this
thanks ahead of time
cody
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 01-30-2008, 11:40 AM   #2
dadsbrew
dadsbrew's Avatar
Re: High idel speed
check for vacuum leaks, either around the base of the carb or any vacuum lines, possibly internal vacuum leak in the carb. 18 degree's is advanced alot is the advance still hooked up when your setting the timing.
1970 K-10 400CID, to much cam--not enough compression Stan's Headers and a 4" lift / 1990 R1500 Suburban 4X4, 350CID with vortec heads, edlebrock intake, TBI, 10:1 compression and Stan's Headers
"The probability of someone watching you is directly proportional to the stupidity of your actions"
dadsbrew is offline   Reply With Quote
Old 01-30-2008, 12:58 PM   #3
cruiserman
Re: High idel speed
Turn down the idle speed?
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 01-30-2008, 01:51 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Re: High idel speed
I had a similar problem and fixed it by putting on a heavier return spring.
Danny
Shyguy is offline   Reply With Quote
Old 01-30-2008, 02:05 PM   #5
dadsbrew
dadsbrew's Avatar
Re: High idle speed
yes, I would definetly return the throttle by hand to see if it can come back farther, if it does use a heavier spring, good idea shyguy
Old 02-01-2008, 08:30 AM   #6
tx71smallblock
Re: High idle speed
Has after market heavy spring, brand new carb, idel screw is backed all the way out
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 02-01-2008, 11:52 AM   #7
haysonj
haysonj's Avatar
Re: High idle speed
Your secondaries are partially open could be bent rod or just dirty or out of adjustment try to manually close them or look down in the carb to see if one of the screws has come off the butterflies. You should also check the choke cam to make sure it is not holding the throttle open
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 02-01-2008, 12:40 PM   #8
Kager67
what knocking sound?
Kager67's Avatar
Re: High idle speed
Something you could try is to hook up the choke and turn the choke housing a quarter turn counterclockwise (lean). This should make sure the choke isn't part of the problem. My 72 did the same thing and this fixed it.
Kage
1968 C-10
1953 belair two-door post
1955 chevy 3600 big window
1950 studebaker starlite coupe
1968 Impala SS
Kager67 is offline   Reply With Quote
Old 02-01-2008, 12:59 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: High idle speed
Has it run normal before or is this problem since the carb install?
I would remove the carb and check to make sure that butterfly closes almost shut when at rest. Should have just a small clearance.
If all the mechanicals check out, then possible vacuum leak. Don't overlook cracked hoses or possible transmission modulator if auto.
68gmsee is offline   Reply With Quote
Old 02-05-2008, 10:56 AM   #10
tx71smallblock
Re: High idle speed
ok fixed the high idel, the choke cam was holding the throttle open. but now i have a timing question, is the listed 8* btdc before or after you hook up the vacuum advance back up? should i be ideling at 8 with everything buttoned up? or ideling at 8 with the vacuum pluged and then it jump to 10 or 12 with it connected?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 02-05-2008, 12:41 PM   #11
cruiserman
Re: High idle speed
8* base timing, so with vac advance disabled.
05 Odyssey
08 Tundra
Old 02-06-2008, 09:46 AM   #12
tx71smallblock
Re: High idle speed
thanks cruiserman, is that what most of you are running? with what i put on it should i run somthing different?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
