70 or 73-87 A-arms , which is better?
Starting to collect parts for my 1970 1/2 ton. I'm doing the 73-87 spindle swap and wondering if I should use the newer a-arms too or use my factory arms. I'm going to rebuild either set, just want to know which ones would be better to use. The truck will also be bagged if that matter.
A guy with a truck
Re: 70 or 73-87 A-arms , which is better?
The late arms will be cheaper to rebuild. They also offer a better ride due to rubber instead of steel bushings. Both of my trucks have '73-up arms...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Thanks gringo. That was my plan, just checking to see if there was any advantages to the older arms.
