02-07-2008, 01:09 AM | #1 |
Need help on wiring
I am working on my fuel gauge. I have read a lot on searches and FAQ section but I am still a little confused. I have a new sending unit. I have the tan wire running from it to the fuse box but it is not hooked up at the box. Can someone explain to me where it goes or send me a pic? Then on the top of the fuse box where is says fuel gauge, there is nothing hooked to it? Do I need to run a wire from there to the gauge? The gauge seems like it has some power supplied to it because when I turn my ket on it moves a little bit. It points toward the glove box all the time and it may move 1/4 inch when you turn the key on. any advice would be greatly appreciated.
1972 C-10 short bed, 2wd, 350(ls1 coming soon) 1969 camaro ss, 496 stoker, 4sp 2009 crew cab,duramax 2500hd 4x4, lifted (sold) 2008 Daytona Charger, Hemi Orange, 07 C6 Z06 2005 suburban, 2002 grand prix gt 2005 grizzly, 2004 R1 Last edited by camarossrulz; 02-07-2008 at 01:10 AM. |
02-07-2008, 01:49 AM | #2 |
Lemme show you something!!
Re: Need help on wiring
OK- here's the deal on fuel gauges. The tan wire runs from the sending unit to the fuse panel and connects to one side of the fuse holder. There's also a tan wire that runs from your dash panel plug which should be connected to the other side of said fuse holder. Note that the connections are on the back of the fuse panel, which will require the removal of the fuse panel from the firewall.
Hope this helps.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
02-07-2008, 02:10 AM | #3 |
just trying to help, maybe someone else will chime in who knows more, but i just studied the wire diagrams and there is a 20 gauge tan wire that goes from the gauge to the fuse panal, a 20 or 18 ga wire goes from there to the sender. and a 20 ga purple wire from the gauge to the fuse panal. i am asuming that the 20 ga purple supplies the power to the gauge and the tan wire is not hot, i dont think it goes through the fuse panal on other cars. the flutter of the guage might mean that you have power to the gauge but the tan wire is not a complete circut, i would check the tan wire between the gauge and the fuse panal for any possible shorts or mis connections. there is always the possibility that the gauge crapped out too. good luck.
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
02-07-2008, 05:36 AM | #4 |
if i remember right i had that problem and it was a bad gauge sounds like you have all your wires hooked up right
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-07-2008, 06:44 AM | #5 | |
Long Fleet Club
The tan wire is a ground wire going to the sending unit. There is a tan wire that runs from the sending unit to the fuse panel and plugs into the front where it says fuel gauge. You can just plug your tan wire from the gauge into the wire that is coming from the sending unit.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
02-07-2008, 08:17 AM | #6 |
Questionable
Check out the pictures in this thread:
http://67-72chevytrucks.com/vboard/s...ighlight=fuses See how the top of the fuseblock has a male connector post for "Fuel GA"? Run the wire from your tank's sending unit to that jack on the fuseblock. That line is directly tied to your gauge in the dash.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
02-07-2008, 08:18 AM | #7 |
that helps a bunch, I will give it a try tomorrow and see what happens. thanks
1972 C-10 short bed, 2wd, 350(ls1 coming soon) 1969 camaro ss, 496 stoker, 4sp 2009 crew cab,duramax 2500hd 4x4, lifted (sold) 2008 Daytona Charger, Hemi Orange, 07 C6 Z06 2005 suburban, 2002 grand prix gt 2005 grizzly, 2004 R1 |
02-07-2008, 08:20 AM | #8 | |
that was confusing me because that pic showed the tan wire connected towards the bottom of the fuse box. I was thinking that it should have went to the one that says "fuel gauge". thanks for the help
02-07-2008, 08:42 AM | #9 |
Questionable
I think you mean you think it's the tan wire at the bottom of this picture?:
http://67-72chevytrucks.com/vboard/s...61&postcount=6 See next post ....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-07-2008 at 10:54 AM. |
02-07-2008, 09:52 AM | #10 | |
Long Fleet Club
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 02-07-2008 at 09:53 AM. |
02-07-2008, 10:54 AM | #11 |
there is some other wire plugged in on mine where the picture is showing the tan wire. I am not sure what it is
02-07-2008, 10:58 AM | #12 |
Questionable
Two questions: Can you please trace where it is going? What color is the wire?
02-07-2008, 11:01 AM | #13 |
I will have to look it over tomorrow. I ran out of time today. cant remember the color but I will look tomorrow. If I cant figure it out, I will try to post a pic maybe that will help.
02-07-2008, 12:37 PM | #14 |
Long Fleet Club
That is becouse the tan wire is in the wrong spot if it is for the sending unit in those links.
02-08-2008, 02:52 AM | #15 |
well, I put a new end on the tan wire from the sending unit and plugged it into the prong that says fuel gauge. when I turned the key on the gauge went to about 3/4, which is about what the tank has in it. So I think everything is working now. I wish all problems were fixed that easily. I want to thank everyone for the help.
02-08-2008, 03:07 AM | #16 |
Long Fleet Club
No problem just wish i wasn't as medicated on my first post so you could have got it yesterday. Some reason I was thinking you were installing a new gauge.
02-08-2008, 04:51 AM | #17 |
Questionable
I'm glad Chris came in and told me I was right - I posted that info above after having a couple of beers and thought for a second that I was grossly wrong - I couldn't remember how I hooked mine up, but I swore that what I posted was right.
02-08-2008, 05:16 AM | #18 |
Long Fleet Club
always good to work on trucks with a guy that had a few beers and a guy that has medication that causes drowsiness
02-08-2008, 05:28 AM | #19 |
Questionable
