User #12137
![]() Join Date: Apr 2004
motor mount ???
i need to see a pic ( in the truck if possible) of motor mounts (small block) 70 3/4 ton 4x4
the resion i ask is i got a box of parts when i traded for the 3/4 ton 4x4 and its got mounts in there that i have no clue on i thought the motor mounts bolted to the cross member , but the ones in the box of parts got sumkinda stand to them thanks , tnblazerk5 |
Re: motor mount ???
If the crossmember has two brackets for the engine mounts then you probly have the 73+ style, the 72- style is a big U and the engine mounts bolt directly onto the U shaped crossmember, basically all one piece were the 73+ style is a 3 piece setup..
Hope this helps..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
![]() Join Date: Feb 2000
Re: motor mount ???
Here is the factory setup that I'm using in my 69 K20 - ignore the bbc and the washers that you see circled in red - they were used to raise the motor slightly for oil pan clearance.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
User #12137
Re: motor mount ???
burt4x4 the parts in the box are not 73 up , i have built a bunch of those
thanks for the help thanks Yukon Jack thats what i thought they looked like i have no clue what they came off of ![]() |
Re: motor mount ???
Oh well it was a good guess
![]() good luck ![]()
