Old 01-17-2003, 09:06 PM   #1
MJN
MJN's Avatar
Anyone else have this problem?
When it gets cold out, my shifter on the column gets very stiff and you can't pull it toward the wheel to get it out of park, you can only pull it straght down. It gets back to normal when it warms up outside. Any ideas? Is something binding when it gets cold? Thanks
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-17-2003, 09:20 PM   #2
jku72
Cold oil is stiff oil. i suspect that the linkage got lubed someplace with the wrong oil. Or, it could simply be that the trans oil is that thick, but if it is......
There is a bushing in the column, it is conceiveable that it got some grease on it at some point, and grease is like tar when really cold. Spray what you can with a really light oil like wd 40, it might help. Maybe.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 01-17-2003, 10:50 PM   #3
baggedblaz
mine does the same thing , the bushins in the column on the shift shaft are not greased up enough and he is right but i think its not from improper grease its no grease, try the wd thing i'm letting mine go and getting some new parts to do a quick repair.
'82 chev swb 4dr 2wd project
'72 2wd blazer LT1/4L60E "SURFSIN" bagged 20's
'71 2wd blazer
'95 chev 2wd Xcab swb
baggedblaz is offline   Reply With Quote
