![]() Join Date: Jan 2008
allignment shim bolts/ studs?
Is there a place to get longer allingment shim studs or bolts for the uper a-arm? I was told if i run 2 1/2 inch spindles and 3" springs I'll run into problens with enough thread on the studs for the ammount of shims it will take?
1972 Chevrolet SWB
Re: allignment shim bolts/ studs?
I have replaced the stock studs with high grade longer than stock bolts and just tack welded them on the backside to hold them on a few trucks. I know alot of guys who use this same method. Most times a 2" coil drop will get your stock studs almost maxed out for camber adjustments and when a 3" coil is used is when longer than stock studs/bolts are needed.......the spindles really dont contribute to more or less shims for the alignment,just the amount of coil drop.
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
i have that drop on mine, and have not had that problem.
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
I just ran into that problem going from 2 to 3 inch drop coils. I bought some upper A Arms from Brothers that are supposed to address this and hope to install them soon. Right now, driving around with too much camber. Drives ok but I'm sure the tires will wear out soon.
I thought of the longer bolts but I'm more of a "bolt on guy" than a fabricator. Might take a welding class soon as that seems to be the most handy skill to have. |
