Old 02-09-2008, 03:05 AM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question Pics of Master Cylinder Plumbing 67-70's w/ Discs
trying to get some ideas on brake line routing (under the hood) since I have installed a disc brake kit, master cylinder, and disc brake proportioning valve..... any pics would be appreciated!!!!
and..... has anyone double flared their own lines? I performed a search and found some posts but does anyone have some words of advise on flaring tubing?
thanks!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 02-09-2008, 07:22 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Pics of Master Cylinder Plumbing 67-70's w/ Discs
No pics but there was a great write up on double flaring and bending tubing in one of the truck mags a couple months ago.It's been years since i did any double flares but the trick is to not split the tubing at the flare.
You might try Classic Trucks or Custom Classic Trucks website for the article.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-09-2008, 10:42 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
tcb-1,... most auto parts stores that "loan" or "rent" tools should have a Double flare tool. It's actually pretty easy once you do a couple. Get some extra brake line (or old line) and practice a little. Or you could contact Inline Tube or ECE and buy pre-bent factory lines. I bought a tubing bender and double flare kit years ago and it's well worth the investment. (plus you can use it for steel fuel lines) You don't use it all the time,... but when you need it,... it's the only thing that will work. I think some of the conversion disc brake companies make a "longer" rubber brake line (that attaches to the caliper) for the 67-70 truck. The 71-72 trucks have the rubber line connect on the "opposite side" of the crossmember compared to the drum brake trucks. Talk to Stan at ECE. They will be glad to help you out. If you were closer,... you could borrow mine.
Keith
Convert to disc brakes.
Old 02-09-2008, 11:02 AM   #4
tcb-1
tcb-1's Avatar
Panel,
I think Classic truck ran that article. As a matter of fact, it's online becuase that's where I found it.
Lo,
Hey man, thanks for the offering on the tool. Well, I do have a flaring tool right now and I have "kind of" figured the flaring thing out. I saw a handheld hydraulic flaring apparatus that looked very interesting, but blowing $300 on a tool I'll only use once is ridiculous!
BUT, I think I won't need to flare any tube right now. I have snaked the tubing that's attached to the frame (right below the master cylinder) so that it is mating up pretty good to the new proportioning valve.
Oh yeah, Lo. I did get new flexible brake hoses with my kit from GMCPauls/McGaughys. So I'm good there.
On a tangent note note, I have really starting using NAPA for all of my brake fittings and adapters. They by far have the most brake related items I have found.....
Doug
