Disc brake help!!!
I am having some real difficulty finding a disc brake kit for my 72 K10. We are keeping the rear 12 bolt (currently drum) and the Dana 44 (currently disc.) I would like to replace the front and rear brakes with larger diameter disc brakes. We are going to use 17" or 18" wheels (6 on a 5.5) on this build under a 4 inch spring lift with 33" tires. I have contacted Baer, Wilwood, Brembo, TCE, SSBC, etc... and they do not have anything that would work with my current setup.
Has anyone found a kit that will work on the K10? |
Re: Disc brake help!!!
I've been looking for a couple years now, and haven't found any type of kit to fit any of my K series. I figured that I'll just live with what I have, or custom fab something when I get the time.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
I find it hard to believe that after being around for over 40 years, no one has made a disc brake kit for this style of truck!!!! There has to be one out there somewhere???
chevy truck fan
have you tried classic performance products (cpp)?? that is where i & fastfun both got our kits. it was a fairly easy install. our trucks though are 2wd....
you might try & get a later model rear & then see if there is a after market kit for it... good luck! |
Yes, I tried CPP. They have a lot of inventory for 2WD trucks but nothing for 4WD trucks. Is there a larger market for disc brakes when dealing with D60's and 14 bolts?
![]() Join Date: May 2003
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
madcow
azsmokey. I changed out the brakes on my 1970 K10. I used The Chrome Guy in Glendale. He had a kit but I only have a 4" lift and 32's. I only did the front and left the backs drum. Works great. I live in Glendale also if you want to check it out I can meet you somewhere.
_____________________________________________ 1970 SWB 4x4 350 4 speed Factory AC |
After a lot of looking around, I found kits for the front and rear at SSBC. The kits are a little more pricey but are good quality. I have used SSBC before and they have been worth the money.
The rear kit: Part # A126 The front kit: Part # A126-10 |
