Old 02-12-2008, 03:24 PM   #1
Blue_71
Bloo
Blue_71's Avatar
dana 44 rebuild questions
i believe the K20 is ready for an axle rebuild, after having it on the road about 75 miles i have a nice roar coming from the left front (wheel bearing) and an occasional clang that sounds like its in the front end.. i do know the u-joints in it are bad. so anyways, to the questions:
is a big hub dana 44 wheel bearing any different to change then a small hub? ive done wheel bearings on a 78 dodge 1/2 ton dana 44 and a 81 chevy 1/2 ton 10 bolt, but never a pre-76 3/4 ton.
are the front axles c-clip axles? i assume they are, and ill have to take off the differential cover, and fully remove the front axles to replace the u-joints on them, correct?
is there an axle bearing at the end of the tube, like on a semi-float rear end?
thanks for any help!
Josh
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-12-2008, 04:06 PM   #2
Mudder
Mudder's Avatar
Re: dana 44 rebuild questions
No C-clips Josh. They both come out from the outside when you take the hubs and spindles apart. There is a seal on the pumpkin but can't remember is there is a bearing or not. Probably so.
Mudder is offline   Reply With Quote
Old 02-13-2008, 04:33 AM   #3
earl87gta
earl87gta's Avatar
the only bearings are the carrier bearings and the wheel bearings in the hubs you shouldnt even have to take the diff cover off just pull the hubs apart and the axles will come right out. while you have it apart i would think about changing the ball joint if they havent been changed and have some one drill the passenger side knuckle for cross over steering.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 02-15-2008, 01:37 PM   #4
msgross
msgross's Avatar
the knuckle doesn't have to come off though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-15-2008, 07:38 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
There is also a small bearing inside the inboard side of the spindle. I think its called a torrington bearing.
It sucks when you reinstall the axles, and push all that dirt into your diff.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-16-2008, 12:12 AM   #6
earl87gta
earl87gta's Avatar
True but It would save time to do it all now and get it over with . He is going to a 6in lift so it may save him some time down the road to do it now and get it over with.
Earl
Old 02-19-2008, 06:46 AM   #7
Blue_71
Bloo
Blue_71's Avatar
ok, left side is completly apart.. i am going to have to replace the ball joints, as theyre bad, and the little needle bearing is bad inside the spindle.. i was going to attempt to do both sides this weekend in the yard, but after getting that apart i loaded up all the parts to take to work where i have a metal bench, press, and parts washer at my disposal
i do have one more question-- is there nothing to keep dirt from getting into the axle tubes on these things?? i thought for sure there would at least be a seal at the end of the tube
1989 Chevy K2500
Old 02-19-2008, 08:48 AM   #8
msgross
msgross's Avatar
nope, only seal is near the diff center....
NAPA has a bearing kit for that.. BN1, BR1, BA1 or something is the part number, comes with a few parts that I had a hard time getting...
The Garage:
Old 02-19-2008, 03:58 PM   #9
earl87gta
earl87gta's Avatar
I think its mad4x4 that has them i may be wrong Ill look it up when I get home . but they make an axle seal that goes on the outer axle tube to keep water and trash out but there like $50.
Earl
