02-12-2008, 01:41 AM | #1 |
options for fuel injection
ok guys,most of you remember my truck,some might not,anyway,its a 72 4x4 w/ 350 crate engine,th350 and a np208 transfer case w/ 3.73 gears.i want to update the drivetrain a little.mainly i want to add fuel injection,and maybe go with a 700r tranny.what i need help on is what have you guys done,all info would be great.did you guys do efi,tpi,what adapters do i need to run a 700r with my transfer case.please,any pics would be great as well.thanx
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
02-12-2008, 02:15 AM | #2 |
Long Fleet Club
Re: options for fuel injection
This is the fuel injection I'm going with
This is what I was going with when I was going to go TPI Here is the solution for the TV cable on the 700r4. They also have one for the '82 - '86 TCI® TCI® Automotive
151 Industrial Dr. * Ashland, MS 38603 Phone: 1-888-776-9824 * Fax: (662) 224-8255 www.tciauto.com Constant Pressure Valve Body™ Now Available For 1987-92 GM 700R4 Transmissions Latest TCI® Constant Pressure Valve Body™ for GM 1987-92 700R4 eliminates low line pressure condition and ensures perfect transmission operation Guarantee proper performance with your 1987-92 GM 700R4 automatic transmission by installing a new TCI® Constant Pressure Valve Body™. Many street performance enthusiasts incorrectly install the critical TV cable that is used to set internal line pressure and part throttle shifting by either leaving it disconnected or improperly adjusted. The result – less then optimum line pressure that results in clutch and band slippage and ultimately, transmission failure. Until recently, the TV cable adjustment on GM 700R4 transmissions often required an experienced mechanic. Compatible with stock and aftermarket transmissions, installation of the TCI® 700R4 Constant Pressure Valve Body™ avoids common transmission destruction by maintaining adequate line pressure at all times. While the TV cable still needs connection for proper transmission operation, the TCI® 700R4 Constant Pressure Valve Body™ provides more liberty when setting part throttle shift points and works with a variety of cable brackets and carburetor applications. For more information about the TCI® 700R4 Constant Pressure Valve Body™ or any other TCI® product, call us at 1-888-776-9824, or visit us online at www.tciauto.com. Quick Summary Product: TCI® 1987-92 GM 700R4 Constant Pressure Valve Body™ Part Number: #376020 Features & Benefits: • 1987-92 GM 700R4 Constant Pressure Valve Body™ eliminates low line pressure due to improper TV cable adjustment • Street & mild race applications • Still maintains part throttle shift points with TV cable adjustment • Works with wide variety of throttle brackets and carburetion systems • Compatible with stock and aftermarket transmissions; installation instructions included
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
02-12-2008, 05:41 AM | #3 |
wow,thanx,those are some great choices,i could use some more if yall got em,i was wondering what would i have to do if i wanted to do a 4l60e as well
02-12-2008, 03:22 PM | #4 |
I have a 69 4x4 swb and I bought the holley commander 950. It's installed, well almost installed and has been almost to easy to install. Depending on injector size and what your motor can handle it's suppose to be good over 1,000 poneys. I got the system with injecters for 400-450 horses. Holley has been great in the technical service department and have answered all my questions regarding the product. The draw back is that you have to use a lap top to program the system, but it's nice to know that holley is there for you. Go to holley.com for info.
02-12-2008, 07:00 PM | #5 |
sounds good,keep em comin
