Heater hose rout
Just wandering if I had my heater hoses hooked up correctly on my 1980 k20. I have one hose coming out of my water pump going to the top of my heater core, the other is coming out of the bottom of my heater core and going into the front of my intake manifold. The reason I am not sure is I dont seem to be getting much heat at all. Any input would be great!
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Heater hose rout
Sounds right to me. The one comming out of the intake is the feed line to the heater and the one to the water pump is the return line. Although on some models the return line feeds straight into the radiator just below the Rad cap. Evidently yours doesn't.
I'd start by making sure all the air is out of the system by letting it run at a high idle for about 5-10 minutes AFTER it comes up to normal operating temperature with the Radiator cap off. Keep an eye on the fluid level and top it off as needed. Check the temp of both heater hoses... Are they the same? or is the return hose considerably cooler than the feed hose? If so you've got a blocked up heater core and will need to flush it out or replace it. If still no heat, your next course of action would be to replace your thermostat thats obviously stuck open and not allowing the coolant to remain in the engine long enough to get hot. In the summer time this can also cause overheating because again the coolant isn't staying in the Radiator long enough to be properly cooled down.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
BAD BOW-Silverado XST
#4 | |
There's more forced flow coming out of the intake than there is coming out of the radiator.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 02-13-2008 at 12:32 PM. |
| Bookmarks |
