Does anyone know where I can find a wiring diagram of the harness coming out of a GM Tilt column? I have no idea what year the column is, it was in the truck when I bought it.
thanks, CJ |
Re: GM Column help
With pictures someone can probably identify the column. from there you should be able to find the diagram you need.
Re: GM Column help
I will try and get some pics. It is a flat rectangular plug with 10 wires in it.
![]() Join Date: Oct 2006
Re: GM Column help
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
KOFFIN DRAGGER
Re: GM Column help
color function
black horn light blue left fr signal blue right fr signal brown hazzard purple flasher yellow left rear signal green right rear signal white brake switch there are 2 sizes of connector: 3 7/8 and 4 1/4 |
Re: GM Column help
Thanks for the info. I was able to get the turn signals working earlier today. Now the only problem is they won't flash when the headlights are on. It had a new wiring harness "installed" by the previous owner.
Re: GM Column help
any ideas why the turn signals stop flashing when the headlights are on or the brake lights come on?
Re: GM Column help
I would guess a bad ground. I would start looking for it at the tail lights. Take a long piece of wire. I use an old extension cord with the ends cut off. tie one end to the neg terminal of battery then the other to the rear grounds. then test to see if the problem is still there. Does all the lights work? do they all seem to be bright and even?
Re: GM Column help
they all look pretty bright, right rear may be a little dim. thanks for the info, I'll try checking the grounds
