BlahBlahBlah
Lowering springs pic...burb vs truck
I dont know if you burb guys knew they make heavier duty lowering springs for burbs and panels. It came up on the board the other day so I dug out my springs and I snapped a pic of the two different styles for everyone. Both are 4" lowering, one for truck and one for burb/panel.
It just doesn't matter
![]() Join Date: Apr 2001
Re: Lowering springs pic...burb vs truck
Not to hi-jack, but where did you get the ones for the Burbs? Do you know if they offer different drops?
05 Chevy Silverado..... A rogue BMW guy.... If you don't like me- TAKE A NUMBER; There are people ahead of you!! |
BlahBlahBlah
I dont know if they make different drops. I got them from PICKMUP here on the board. You will have to ask him.
![]() Join Date: Aug 2005
Good info CG. I've seen that they list them seperatley in some catalogs, but never saw the physical difference.
turbo enthusiast
thats got to be the rear springs, right? Makes sense, cause burbs and panels have alot more weight in the rear.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
Tot Roddin'
How well would the Burb springs work on a truck??? Or would they?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
its all about the +6 inches
That is quite a bit huh? Thanks for showing this Mark... a LOT of us didn't know about this.
And Joe... welcome to the burb club! |
I am a Referee of life.
I didn't know.I have the springs (4 in drop) on my panel.I haven't had weather/time to do the spindles yet.I am hoping for the stance to be what i want but had thought I may have to go to a 3 in spring.I also may do some light towing(small travel trailer) eventually and the heavier spring may be the ticket for that.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
67-72 Addict!
Mark, can you place a tape measure down thru the coils and do a measurement comparison of height?. The thick one looks almost 1" shorter!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Insert Title Here
so if you put truck springs on a panel, it would be slammed
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
BlahBlahBlah
Yeah its shorter but as you can see a lot more stout. Im guessing there isnt much give when you set the body down compared to the truck version.
laying low
![]() Join Date: Mar 2001
I bet it would be bouncy, to say the least, due to the lighter spring and heavier weight of the burb.
BlahBlahBlah
![]() Join Date: Dec 1999
I have 5in truck springs in the rear by McGaughys on this burb
#15 |
laying low
I know you are bound to carry some weight in that burb. So are they any softer than the original springs?
#16 |
I ordered 6" drop coils from ECE for my burb and when I let the jack down, there was about an inch between the rear and the frame. Sent 'em back and got airbags.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
#17 |
Tim, are you runnin a notch in the rear of the Burb ? How is the ride with the truck springs ? cant decide which way to go ,springs or bags now another choice on the springs. Maybe that is why Dave at ECE recommended 3.5 front and 5 rear cus the burb springs are shorter than the truck. Concerned about the effecte of almost 500 Ft lbs of torque from the Cad! Thanks! Steve
