2 barrel cast iron intake FS.
I don't know what the need is for this, but I know circle track guys like these. The part number is 6263752. Very heavy, so prefer local pick up as shipping will be high I think. 15.00 plus shipping. If it isn't worth anything let me know and I will put it in the scrap heap.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 02-15-2008 at 02:55 AM. Reason: Better Pics. |
Re: 2 barrel cast iron intake FS.
the circle track guys use Canadian 2 bl intakes. The carb holes are bigger.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Thanks for the info. I don't know a thing about circle track. That is just what I was told by a buddy that races.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Does it say Made in Canada anywhere on it? If it does, could you post a picture? I've never seen a Canadian 2bbl intake and would like to know what to look for.
