Old 05-20-2002, 08:15 AM   #1
Nichboy
Post Poly tank problem
Anyone who has installed a poly tank have this problem. Tank is collapsing on passenger side and trying to come up into frame. I have loosened the straps with no luck.
1971 Chevy SWB
Oklahoma City, Oklahoma
Nichboy is offline   Reply With Quote
Old 05-20-2002, 08:23 AM   #2
busterwivell
Post
I haven't installed mine yet, waiting for filler neck I ordered. How close is that tailpipe to your tank? could it be melting the tank?
56 Studebaker 2 dr Wagon
66 Chevelle 2 dr 4 speed
71 C30 Longhorn
86 Monte Carlo SS
96 Tahoe
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 05-20-2002, 08:36 AM   #3
Nichboy
Post
There is about 6" clearance between pipe and tank. Also i am having no trouble on drivers side.
1971 Chevy SWB
Old 05-20-2002, 09:10 AM   #4
Low69CST
Post
Looks like your straps might be too tight. Or, do you have the tank vented very well? If the vent is clogged up then the fuel pump might make it colapse.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front & rear sway bars
See my truck at: http://www.geocities.com/low69cst/
Student at the University of Kentucky.
Feel free to message me on AOL, SN- SS95ZQ8
My Dad's projects:
72 Short Fleet 4x4 Chyenne Super
72 Long Fleet 4x4 Chyenne Super
Both 350 autos restored original
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-20-2002, 09:18 AM   #5
Nichboy
Post
I have loosened the straps quite a bit, i hate to loosen them anymore but i may have to. It's vented ok, everytime i fill up it runs out the vent hose. There was a lot of play between the frame rails when i installed this tank, i think it has shifted towards the driver side and the passenger side is coming up between the frame, but i don't understand why the tank is warping. It has been like this for a couple months and has not gotten worse, so i don't know if i ignore it will it hurt anything. Thanks guys
1971 Chevy SWB
Old 05-20-2002, 09:37 AM   #6
Low69CST
Post
Drive the crap out of it, then reach under and feel the gas tank. If it burns your hand then its melting. You think that because the tank is resting on that very outter tip its putting a twisting force on the tank and making it colaps? Like if you sit on the edge of a box then that side will colapse.
My Dad's projects:
Old 05-20-2002, 11:16 AM   #7
Nichboy
Post
Hey LOW69 did you have any side to side play between the frame on your tank install. Do you have any tips on keeping the tank centered between the rails. Thanks
1971 Chevy SWB
Old 05-20-2002, 11:30 AM   #8
Low69CST
Post
The "first" time I installed my tank, I had the straps bolted too close to the inside of the frame. What happend was the straps kept the ear on the tank from catching on the bottom of the frame. So I had to redrill the bolt holes for the straps farther out on the frame which gave me more room to move the tank side to side and more strap adjustment. I just pushed the tank to the center spot. I haven't driven my truck yet, so i don't know if it will slide or not. Probably 2 small bolts to be screwed to the frame on each side of the tank, right against the 2 ears. One on each side would stop the tank moving side to side.
My Dad's projects:
