Old 03-05-2005, 12:36 PM   #1
3quartertime
My Mistress the Sea
3quartertime's Avatar
4WD Class 101
Got a problem. Either I don't know how to engage the 4WD in my truck or it doesn't work. Truck is a 71 K20 with spicer lock-outs. Don't know the type transfer case or front end.
I spin the lock-out hubs to lock and with the truck in neutral I try to engage 4-lo. Only back tires spin. Tried 4-hi same thing. Can't turn front drive shaft with hand in either. But in 2-hi it turns by hand. So I'm thinking the tranfer case is working, thou I haven't actually seen the driveshaft spin while the truck is moving.
Sooo,,, either I don't know how to engage 4WD in the truck ( Which I would be grateful if someone could school me!!!) or my lock-outs aren't working. Or a little of both!!!
If it's the lock-outs what is the most likely problem?
Thanks for any help...
3quartertime is offline   Reply With Quote
Old 03-05-2005, 02:13 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If your manual hubs are not working and the transfer case is in 4wd hi or low the front driveshaft should still turn. Since when the transfer case is in 4wd hi or low you can not turn the driveshaft(it's locked to the rear) then the transfer case is working.
is that the transfer case or tranny? If you have the both hubs locked and the transfer case in 2hi, the front drive shaft should not turn as the tires would want to turn, if you can turn it I'd say your hubs(at least one) is bad.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-05-2005, 07:51 PM   #3
Americanrider
Which type of transfer case are you running? I would look into the transfer shifter to make sure it's hooked up & working properly, might be an easy fix.
Americanrider is offline   Reply With Quote
Old 03-05-2005, 10:06 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, sounds like its engaging but not working. Might be one of the hubs or something easy with the transfer case, hopefully.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-05-2005, 10:09 PM   #5
Destructo
I had a similar problem, hub didn't have enough grease in it and wouldn't operate freely and it wouldn't lock.
Take the hubs apart, clean them up and re-grease them well and put them back in.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 03-06-2005, 09:03 AM   #6
Blazer1970
Blazer1970's Avatar
Yup, one or both hubs are not locking.
Blazer1970 is offline   Reply With Quote
Old 03-07-2005, 07:29 AM   #7
ZOOMY
What Blazer or Destructo said, or a u-joint in the axle-shaft is torn right out. (I just did that last fall).
ZOOMY is offline   Reply With Quote
Old 03-08-2005, 08:36 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Whatcha find out?
Old 03-10-2005, 12:11 AM   #9
3quartertime
My Mistress the Sea
Originally Posted by JIMs70GMC
Whatcha find out?
Nothing yet!!!
It's been cold in these parts and I work outside. No motivation to crawl around under the work truck after being cold all day unless whatever is broke makes the truck not go...
I'm waiting for a better day to try all the suggestions.
I'll report back!!!
Thanks.
Old 03-12-2005, 01:05 AM   #10
Blue_71
Bloo
Blue_71's Avatar
when you hit lock, can you turn the hubs any further? i think my truck has 1/4 turn hubs but i think ive heard of some that take a pretty far turn to get them locked... they should hit lock and not be able to go any further
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-12-2005, 10:43 AM   #11
nu2-72
First, you will have large spicer hubs if they are original. The knobs are supposed to read "Spicer" with an arrow pointing position. If the name plate is gone, just remember that it runs straight with the center raised part of the knob. The arrow or straight line should line up with "Free' or "Lock" and go no further in either direction. About 1/4 turn. If it turns further your tab on the knob is broken. This will not stop the lockouts from working but will turn them slightly too far one way or the other. The knob will still stop each direction but just a little too far.
Next, if the knob will rotate 360 degrees you have broken ears and the pin is no longer stopping rotation. The knob has a pin that rotates a metal sleeve inside the assembly. This sleeve is spiral cut to rotate out and apply pressure to the clutch gear pack. If it does stop in the rotation suggesting the that the ears and pin are OK, then you may have too stiff of grease or broken internal springs. The springs push the gear pack out to disengage but if broken may prevent engagement.
Put the truck on stands. Engage the lockouts. Put the transfer case in neutral. Turn the front driveshaft. The driveshaft and wheels should be locked together and the wheels will turn. Transfer case is disengaged.
Take lockouts out. Place the transfer case in high or low. Front and rear should now be together and rear will turn by rotating the front shaft. If not, you are not engaged in the transfer case. Pull the linkage to make sure it is engaged or remove the linkage and make darn sure that you feel it lock in by hand.
May just be adjustment of the shifter.
If high works but no low, try adjustment. If neither high or low work. Troubles.
There is a thread here about "How To" . Look at the pics and you can see the ears and pin hole and the tab.
Good luck.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 03-12-2005, 10:53 AM   #12
nu2-72
See if this helps. Hope it is clear.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 02-20-2008, 07:37 AM   #13
IBAPIGFARMER
IBAPIGFARMER's Avatar
Re: 4WD Class 101
Does anyone know if you can still get a rebuild kit for the original spicer hubs?
(I.E. Yellow knob,pin,spring,etc.) or do you have to go to a replacement hub?
IBAPIGFARMER is offline   Reply With Quote
