02-13-2008, 01:15 PM | #1 |
Happy Camper
72 spindles on a 69
Well my cousin (member El Jay)'s computer is down and is in the process of getting a new one. He asked me to ask the gurus here because he was sitting in one of his two peekups listening to the radio in his driveway, when a feller drove up in his a '72. He said that he had another '72 on his property that he has parted out everything that he needs and wanted to know if El Jay wanted a set of '72 spindles for his '69, I searched but everything came back "drop spindles".
Long story short (too late ), what would he need to know and what else would he need to purchase to make this happen. Any input would be most awsome dudes. Thanx JJ
RIP El Jay! Love you brother! |
02-13-2008, 07:04 PM | #2 |
Re: 72 spindles on a 69
The upper ball joints have to be replaced and the tie rods used from the 72. I cannot think of anything else that is needed but if changing to discs, using the whole cross member assembly from the 72 is an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-13-2008, 08:12 PM | #3 |
You will need to use the upper and lower ball joints from the donor truck, but they will bolt/press in the the '69 control arms. The tie rod ends are the same, but the tie rod (threaded part) on the 71-72's is larger in diameter.
trailers are for boats |
02-13-2008, 11:13 PM | #4 |
I am doing the same swap and I pulled all my parts off my 72 donor truck. Ordered new ball joints from ECE....
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! |
02-13-2008, 11:54 PM | #5 |
Happy Camper
Great guys, this is what he needed. I will pass it on tonight. Then I may have to have a look @ the guys leftovers for myself.
02-14-2008, 12:08 AM | #6 |
i have a set of freshly powder coated spindles off of killer if things fall through
R.I.P. Killer 71 10/26/07 |
02-14-2008, 02:13 AM | #7 |
Son of a gun
You also have to trim the steering stop on the 72 spindles, but it's doable. About the tie-rod ends, you will need the whole tie-rod form the 72. The drum brake tie-rod ends are different, and 72 ends will not work with the drum brake inners. I found that out the hard way.
Bill BEATERS ARE NEATER |
02-14-2008, 05:07 AM | #8 |
Does anybody have a picture of trimming the steering stop.
02-19-2008, 01:35 AM | #9 |
Happy Camper
That would be a big help too!
02-20-2008, 03:53 AM | #10 |
Son of a gun
Jerry, this is what I did. So far it is working fine. This picture is from the rear of the passenger side spindle. Trim along the red line.
02-20-2008, 08:30 AM | #11 |
Happy Camper
Thanx BTK, you da man.
