Old 02-20-2008, 05:26 AM   #1
69 air cab
outside cleanup of a gass tank????????????
I have a good gas tank for my 69 truck but it needs some cleanup on the outside. It's been empty and out of the truck for about 4 years. Can I use a grinder bursh on it or will it still blow up on me? Any suggestions?
69 air cab is offline   Reply With Quote
Old 02-20-2008, 05:32 AM   #2
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Re: outside cleanup of a gass tank????????????
I cleaned mine with Scotchbrite and Simple Green, wiped it down with a solvent cleaner and sprayed it with Eastwood's gas tank paint. It turned out pretty nice. I don't believe I would use a wire brush. The finish on the tank is a soft coating and a wire brush would gouge the finish.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 02-20-2008, 05:35 AM   #3
69 air cab
thanks........I'll give that a try
Old 02-20-2008, 10:11 AM   #4
bartstoy
bartstoy's Avatar
I took my tank to a local radiator shop and had them clean it out, because I could hear stuff rattling around in it. Don't forget to replace the sender unit, the filter is probably gone.
Original owner '69 C20, long, fleet.
454 BB with Edelbrock stuff.
Work truck for years, 2nd restoration going on.
'69 C20
'03 Tahoe Z71
70 Hp Johnson pushing aluminum bass boat.
All things in life are uncertain, so eat dessert first.
bartstoy is offline   Reply With Quote
