Re: Old Navy 50's era trucks for sale
Thanks for the info!!
I think you are right about it being a GMC since it says GENERAL MOTORS TRUCK on the dash. Hmmm I wonder if the front grill was different then? Thanks again! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Prestige Worldwide
![]() Join Date: Feb 2001
Still never told us about how she scored it for free......
Yup the grill is different and I think the front fenders are too. There are two threads in this forum with pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=276531 http://67-72chevytrucks.com/vboard/s...d.php?t=276883
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, |
The cabs are the same between the Chevy and GMC. Even the fenders are too for the most part. The grills, hood and radiator core support are all different between the two models. The entire front clip can be switched between the cabs without ffew issues. The frame itself has a different cross member at the front for each model. The GMC cross member has a stair step sort of mounting surface and the Chevy cross member has even mounting surfaces. Otherwise besides the cross member they are the same all the way back. Other little stuff like guages, dash lettering are different, as well as exterior name badges of course.
AD's Rule!! 53 GMC Suburban--48 GMC 1/2 Ton project--49 Chevy Pick-up--52 Chevy Pick-up (my driver) ![]() |
