Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-13-2008, 12:45 PM   #51
bigjimzlll
bigjimzlll's Avatar
Re: 72 Lwb
A lot of good info there. On my drag race suspension. Ladder bar with the traditonal perpendicular/behind the axel coil overs, your saying the rear springs play a much bigger part than I could of imagined.
The amount of seperation(anti-squat) is no more than .500-.750". I cant see how stored energy has anything to do with that. It is a function of leverage which I control by the rear shocks...I use the shocks also to control the compression(squat). Am I completely off base here?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-13-2008, 01:23 PM   #52
Super73
Super73's Avatar
Re: 72 Lwb
Think about it this way.. The front stores energy by having a long light spring right? It works the same in the rear. Having compressed that spring X" you have that much preload in it. When you induce antisquat, it's going to put the energy of the highly compressed spring to the tire.
But one thing to consider is too much will do 2 things.
It will counter act some of the front raise. The front should start to come up before the rear does. But as the rear does, It's going to want to push some back on the front.
Secondly, if you have too much energ stored in the rear, as it slams the tires in to the ground, the tires might want to bounce back. This is where a double adjustable shock can help for sure. Loose for the seperation and tight for the compression.
Dave does a great job explaining it. I have his DVD and love it. I could watch it over and over. I always picks something new up on it.
Super73 is offline   Reply With Quote
Old 02-20-2008, 02:09 AM   #53
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: 72 Lwb
Truck looks awesome! Lovin' the LWB dragster
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-22-2008, 10:12 AM   #54
Outlaw72
Hay Team!!
Outlaw72's Avatar
Re: 72 Lwb
Thanks....I really enjoy it!
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
