Insert Title Here
watts link
anyone ever use one of these?
http://totallypolished.com/watt's_link_kits.shtml
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 04-23-2007 at 10:09 PM. |
Re: watts link
Totally Polished does some great work. I've never seen any bad from them, but never been able to afford their parts and such. I'd prefer suicide doors cuz their so often used and do such great work rather than using a company not many use.
Re: watts link
I haven't used a TP one but i did put in a BYC watts and a parrallel 4 link on a truck a few months ago. They work real well with big power, and its stays centered through the suspension cycles.
71' 2wd sub <------parts donations accepted 99' 4wd big block sub 92' K2500 ext cab Lb 95' S-10 sfbd, hydro's, etc. 02' Ram bagged etc. 83' International School bus...flat black with alot of room www.Homegrowncustoms.com |
Insert Title Here
Re: watts link
kp has a nice one too
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Re: watts link
It's prob just me but...... the first thing I would do w/that set-up is grind all those freakin' 'points' off that thing.
Looks like a bunch of arrows pointing all over the place
Insert Title Here
Re: watts link
thats what I like about that one..lol
Re: watts link
Generation gap I suppose....
Re: watts link
I was thinking the exact (too many points)same thing when I scrolled down and read your post
![]() Last edited by BigTruckDriver; 04-23-2007 at 11:28 PM. |
![]() Join Date: Feb 2007
Re: watts link
just make one.. i did.. and saved some money.... built it for about $100
Too many projects
Re: watts link
Look up Speedway Motors and you can get a watts link kit cheap, just have to do some fitting to your truck, I plan on this route.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Re: watts link
yoyo, nice setup. I like your mounting to the axle vs. other Watts. Looks real clean. What brake setup you got going there?
Re: watts link
The totally polished Watts is very nice! I too like the way yoyo mounted it to the axle. I thought about doing mine that way but just ended up going this route.
My .02 is build one. Doesn't take much and you wil save a ton of $$. I'm into mine for about $150.00 |
#13 | |
Re: watts link
Re: watts link
you can get everything through SSD or Pete and Jakes.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
#15 |
Re: watts link
I bought the bearings at Car Quest. The heim joints from the local off road shop. They also made the link bars for me with reverse thread on one end. Works great! I only have about 500 miles on the truck but looks good so far.
#16 |
Re: watts link
i ordered the helm joints from jegs. and the center bushing is from the stock pan hard bar.. no bearings and it stays straight... my breakes are a kit i put together.. bought 2 axle brackets and the calipers are from an 85 caddy elderodo along w/ the hoses...
#17 |
Re: watts link
yoyokidss woul dyou happen to know the length of your watts link bars? I fyou could get that for me I would really appreciate.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
#18 |
Formerly ADHDCARGUY
Re: watts link
Cool work yoyo!
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
#19 |
Restoring a 68 SWB
Re: watts link
Those are some nice DIY Watt's links guys. Are there any "how to's" on the site, or anywhere, about how to build one?
#20 |
The LuvShack Garage
Re: watts link
For all of the Dummies here, what is this for / what does it give you?
#21 |
WTB this ad
Re: watts link
Craig, If I'm not mistaken It's to keep the rear centererd at all times and heights. Track bars always end up pushing the rear over to one side after you go so far with them. If you remember looking at Tim Christians sons orange truck, when he's aired out one of the tires will touch the bedside. A watts link would keep him centered up and keep the tires off of the bedsides. (Not knocking the orange pickup, she's super sweet!). Of course I could be wrong........but I'm pretty sure that this is what they're for.
#22 |
Insert Title Here
Re: watts link
yeah the first link i gave is a video that shows just what it is
