12-09-2006, 01:07 PM | #1 |
Late model (88-98) center caps
I have some 80's style 15x8 truck rallys for my 72. I was thinking of using the later model center caps instead of the original styled metal ones. I have seen quite a few pictures on this site of the later caps on the older wheels (5 and 6 lug) but I cant figure out how they are held on. All the pictures seem to show standard chrome lug nuts and not the threaded lugs with the plastic covers.
12-09-2006, 01:16 PM | #2 |
Yup, I'm comp-useless
Re: Late model (88-98) center caps
You need special lugnuts that are threaded on the outside, to accept the plastic decorative lugnut covers; these covers have a flange around the outside of them, that holds the center cap on.
12-09-2006, 02:24 PM | #3 |
Or, just take out the small plugs in the back of the cap & screw them on from the back of the wheel...
12-09-2006, 03:03 PM | #4 |
That's what I've done. 1/4"-20 screws work perfect. Then use chrome lugnuts.
12-09-2006, 03:58 PM | #5 |
That is perfect. I didn't have a late model cap around to look at. That is cool how those holes line up.
Thanks Again! |
12-09-2006, 03:58 PM | #6 |
67-72 parts finder
thanks for the tips guys i found 2 good 6 lug late model center caps in the bed of my 68 when i bought it although they had all the black caps i want to use regular lugnuts so thanks again guys
1969 chevy shortstep 2wd (under construction) 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
12-09-2006, 05:10 PM | #7 |
That's the same thing I've done with the 1/4-20 bolts, just be carefull tapping the holes and don't overtighten the bolts.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 12-09-2006 at 05:16 PM. |
12-09-2006, 05:27 PM | #8 | |
I actually used the 1/2" conversion lugs on mine since I had to get lug nuts anyway. I'm using the black plastic caps & like the look of the black lug-nut covers.
12-09-2006, 08:39 PM | #9 |
You can buy 1/2" lug nuts with the threads on the outside from some of the aftermarket wheel dealers for $20-$25. They usually come with the plastic lugs to hold the centers on.
12-09-2006, 09:49 PM | #10 |
Those are the 'conversion' lug-nuts I used.
12-10-2006, 04:03 PM | #11 | |
The only thing about using the chrome lugs is I need to use a thin wall socket to get to them.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 12-10-2006 at 04:05 PM. |
02-24-2008, 08:05 AM | #12 |
where can i buy these 88-98 chrome center caps and how much?
02-24-2008, 06:56 PM | #13 |
laying low
From your nearest GM dealer, a salvage yard or the old EBay under truck wheels and accessories.
02-24-2008, 08:22 PM | #14 |
Same but different.I used 9/16 conversion lugs:
02-25-2008, 12:15 AM | #15 |
Those look good on a 4x4 too . . .....
