Old 01-20-2003, 01:24 PM   #1
PloreOSU
Drums on a 72?
I just bought a 72 GMC C-10. The front brakes are drums. I've seen posts on the board that suggest that all 71-72 trucks had front disc brakes.
I'm planning on buying the disc brake conversion kit, but I want to make sure that the spindles on mine are correct first.
Thanks in advance.
72 GMC, 2x4, LWB Fleet
DONE: 2/3 drop, 17" rims, front end rebuild, front/rear sway bars
Working on: old air AC, blazer tank, rear discs, 03 silverado seats.
PloreOSU is offline   Reply With Quote
Old 01-20-2003, 01:54 PM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
Well, either you had a bona-fide Dope-Smoking Old Man work on the truck and convert it back to drums, or you have a '67-'70 frame...sounds strange. Do you have a VIN from the truck?
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 01-20-2003, 01:57 PM   #3
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
yeah, something's definately not right there.
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 01-20-2003, 02:03 PM   #4
PloreOSU
Heres the VIN: TCE142Z508626
Most of the stuff seems correct. The options sticker lists a front sway bar (missing, but the brackets are there), and rear leaf springs plus heavy duty leafs (it looks like there is an add-on pack to the leafs).
I don't know much about the truck because the guy I got it from didn't work on it at all and didn't bother to ask any questions from the previous owner.
Old 01-20-2003, 04:43 PM   #5
PloreOSU
Okay,
Assuming that my truck has been fiddled with, how do I tell the difference between a 71-72 spindle and a 67-70? Is there some sort of visual clue?
Old 01-20-2003, 04:56 PM   #6
jose
jose's Avatar
Vin
Are you sure thats a T in the beginning of vin # ? The spindles are different 67/70 and 71/72 . The vin # without the T shows that it is a 72 GMC 1/2 ton as for the drum brakes it looks like somebody has converted to drum brakes .
jose is offline   Reply With Quote
Old 01-20-2003, 05:08 PM   #7
PloreOSU
Jose,
Yes its a "T", I have the registration in front of me. I double checked that the registration and the truck VIN are identical. The registration claims its a 1972 as well. Unfortunatly I have the original build sheet, but it's pretty well destroyed.
Old 01-20-2003, 05:13 PM   #8
nu2-72
Next step is this, if it is the same as the Chevy trucks, look on the top of the frame rail right next to the steering box. You may have to clean it off a little. The #'s are stamped into the frame and should match your VIN. If not, you may have had a frame swap.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 01-20-2003, 05:17 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Well there isn't a visual clue on the spindles. However there is on the front crossmember. In 71-72 the bracket where the rubber brake lines meet the steel lines are welded to the front of the crossmember. The 67-70's are on the rear. It will be important to know what you have so that when you replace it you get what will work. The tie rod ends and ball joints are also different from 67-70 than 71-72. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-20-2003, 06:37 PM   #10
pound41
I have seen a 72 with drum front brakes. many years ago I had a neighbor who had one. He was always after me to get a new work truck so he could get the front power disk brakes off my 72
pound41 is offline   Reply With Quote
Old 01-20-2003, 09:00 PM   #11
PloreOSU
Another follow up...
The VIN number on the chassis matches that on the body. Also, I went into Midas to have an exhaust leak fixed today and I mentioned the weird brakes to the mechanic. He said that he'd seen a lot of trucks from farmers in Oregon with the drum brakes. So, it looks like I have the old style spindles (the brake lines are attached on the back of the front cross member), however at least I may not have a messed up truck.
Old 01-20-2003, 09:49 PM   #12
Project1970
14.1 @ 96MPH
I can't say I've ever heard of it, but that is a 1972 VIN...
Good luck figuring out what it is and what you need to convert.
Old 01-20-2003, 10:36 PM   #13
Hooter
My other Love
Hooter's Avatar
sounds like one of those weird owners who didnt want discs and maybe ordered it that way. It's like on my old 74, one of the options on the sticker said "high energ ign del" now why would someone NOT want Hei?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-20-2003, 10:39 PM   #14
MOTHERTRUCKERS
71-2 spindles are a 1 piece casting with the tie rod arm cast in,67-70 are a 2piece spindle and the tie rod arm bolts on with 2 bolts.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-20-2003, 11:10 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The T is correct for a 72 GMC also...kinda like the extra C on 72 Chevys.
I have never heard of the drums on a 71/72 either. Is it 6 lug? How about the rear axle...is it 6 lug?
