02-20-2008, 07:18 AM | #1 |
One of the few GMC'ers
EGR Valve???
ok so my 87' keeps throwing codes up for the egr valve. now i have taken the smog pump off of my truck. so now my question is would i be better off to replace the egr or buy/make a block off plate?
87' Silverado 4x4 "Young, Dumb And Full Of Cum" |
02-20-2008, 08:58 AM | #2 |
Re: EGR Valve???
hey, if you're not worried about passing emissions at all then you might as well go with the block-off. Cheaper and will help your engine run a little better
1986 Chevy K10 4x4 305 Auto Last edited by chemsearch; 02-20-2008 at 08:58 AM. |
02-25-2008, 06:55 AM | #3 |
Re: EGR Valve???
anyone else have any input? i bought the block off plate havnt put it on yet will firstthing in the morning. im still a lil weery puttin holley junk on my truck lol
02-25-2008, 09:20 AM | #4 |
1975 C-10 Silverado LWB
Re: EGR Valve???
I don't think egr's are that expensive, but again if you arent worried about smog i would go with a block off. they just put exhaust back through your intake and sometimes crud up the carb if the egr is going bad. Im not sure what you would need to do to use a block off plate and still not get any check engine codes though.
1975 LWB C-10 Silverado - Stock - "BIG 10" - 4 Bolt 350 "Brand new" 1200mi - THM-375 "Brand new w/trans cooler" 5000mi 1995 Ford Lightning - Bone Stock - 351W - Vortech?? |
02-25-2008, 09:53 AM | #5 |
Chris
Re: EGR Valve???
I had to take it off our 84 when I put on an edelbrock carb. I bought the holley plate for $12 and a gasket and blocked it off, then removed the smog pump, now just gotta take off the air tubes. I wouldn't think twice about yanking it off long as she still runs good with smog pump gone you'll be fine I think.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
02-25-2008, 09:58 AM | #6 | |
Re: EGR Valve???
02-25-2008, 10:58 AM | #7 |
Chris
Re: EGR Valve???
I haven't removed it yet just cut the belt off of it.
As far as I know there's bolts that hold it to the block then clamps or something to hold the hoses on to it. Shouldn't be hard to remove I wouldn't think. After removing the egr and even before when you'd rev our up it backfire real bad out the exhaust and the smog pump was doing it, with the belt cut off it doesn't backfire at all.
02-25-2008, 09:43 PM | #8 |
Re: EGR Valve???
You could have easily made a block off plate using parts from the egr and some sheet metal.
1985 Chevrolet C10 305 2wd LOOOOONG Bed Broke as a joke and funny as a funeral |
02-25-2008, 10:49 PM | #9 |
Chris
Re: EGR Valve???
yea but when you don't have the tools or the metal it doesn't leave you with many options.
