Old 02-26-2008, 07:28 AM   #1
Jtrux
I'm a poor spectator
Jtrux's Avatar
AC dash install questions
I found an AC dash already out of a truck this past week and it was in great shape so i'll probably go buy it later or another one. For all you body guys out there what would I be getting myself into to change out my dash for the AC dash. I know that I could just cut the holes and be done with it but some PO of my blazer was apparently a hard core NON smoker and took out my ash tray and patched it. I want it to be completely stock looking so i'm gonna swap out the entire thing.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 02-26-2008, 08:41 AM   #2
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: AC dash install questions
Its not too hard, I'm no professional and I did it
Its in my build thread some where. Take a look and it'll give you an idea. I just cut all the slots down the middle and then the brackets behind. I think I had to take out 2 or 3 bolts on each side in behind the dash too. The hard part is all the spot welding, takes awhile to stitch it in....
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-26-2008, 10:18 AM   #3
Critter
Future TOTM Winner
Critter's Avatar
So you are saying that the horizontal part of your dash where the defrost vents are remained untouched? You made your "splice" under the dash pad in other words? That doesn't sound too bad.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-26-2008, 04:29 PM   #4
vtblazer
vtblazer's Avatar
Correct, it's the simplest/quickest way by far.
Or you could remove the entire dash which will mandate removing all those spot welds and beware, there's alot of em.
Would also mandate removing the windshield doing it that way.
If your hoping to run factory A/C later on, the firewalls are different between A/C and non-A/C trucks also.
The simple fix there is just swap out that area of the firewall from the A/C donor truck.
vtblazer is offline   Reply With Quote
Old 02-26-2008, 07:25 PM   #5
Huck
Huck's Avatar
U have 2-3 bolts on both side--then using any kind of a cutter--just slice the leading edge behind the pad allowing enough metal to overlap or butt up. You will have a little cutting issue at both corners where you unbolted but--it's a whole lot easier then full repl and once done, the pad covers the tac welds perfectly. I've done several---. Pretty easy.
Huck is offline   Reply With Quote
Old 02-26-2008, 09:17 PM   #6
Jtrux
Jtrux's Avatar
That's pretty cool, looks like i'll def have to go back and get one now, I thought it was a lot more work than that.
