Old 02-27-2008, 04:58 AM   #1
botsdots
LED taillights need electronic flasher?
I'm interested in picking up a set of LED taillights. I've found a few suppliers for them and I'm getting conflicting reports that electronic flashers are needed (or maybe not ) for them to work properly. Does anyone have a definitive opinion on this?
TIA!
botsdots is offline   Reply With Quote
Old 02-27-2008, 06:00 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: LED taillights need electronic flasher?
I have the LEDS on the Chief....and they were great...they are SUPER bright.
I usually run without my hood, so I didn't have my front signals. The LEDS would not trip the flasher (would not flash...not enough current).
So I picked up some resistors and hook them up to the LT and RT output to the taillights under the dash.
It worked out perfect.
Now had I of had my fronts hooked up, then I probalby would of need anything.
A single 1157 per side, along with the LED should be enough to cycle a stock type flasher.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-27-2008, 06:03 AM   #3
joe231
joe231's Avatar
Talk to Musclerodz, he is a vendor on here and sells LED tails that have 40 LEDs in each one
here is a link to his profile
link
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-27-2008, 06:22 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
........I used 2 1157 led replacement bulbs and have 60" wide LED bar and my stuff works fine.........no LED's in front.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-27-2008, 07:40 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
link
That's where I purchased mine.....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-27-2008, 09:32 PM   #6
SkylineNXS
SkylineNXS's Avatar
I bought mine from LMC when they had em, and runnin with the 2 1157's up front, there is no need for an electronic flasher, but there not exactlly super expensive to buy.
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
