Old 02-28-2008, 04:21 AM   #1
67cst
i love summertime
67cst's Avatar
emergency brake questions
hey guys ive got a few loose ends on the 67 and i thought id takle the ebrake next. my question(s) is what cable set up do i get? the cab is 67 but the frame is 71. im guessing 67 so that it works with the hand brake under the dash but is the hole in the frame the same size in the 71 frame as a 67 frame? also im running a th400 and its a shortbox and cant seem to find the cable for that application. it shouldnt matter what trans im running should it? if anyone has any info on this could they please help out? thanks
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-28-2008, 05:59 AM   #2
JimKshortstep4x4
Re: emergency brake questions
The 67 front cable is different from the 69-72 cables but the intermediates and rear cables are the same but need to be matched to 2 WD or 4 wd, and transmissions that are used. Leaf springs or coil springs can make a difference, also.
Have you checked with Inline Tube?
I believe that they can solve your problem. Here is a link:
http://www.inlinetube.com/
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-28-2008, 08:49 AM   #3
67cst
i love summertime
67cst's Avatar
thanks for the great link. how did you find out about these guys? they sure are organized on their site. i emailed them with a couple of questions but it looks like ill get everything i need for under 100 bucks! Ill be able to park on hills now...not that i couldnt before but now i can with out worrying about the truck popping out of gear
