windsheild washer pump
when i push in the button, all the thing does is click and nothing comes out. anybody else have this problem?
Old member
Re: windsheild washer pump
More than likely the rubber orffice has let go so it can't pump. I had this happen to several of mine so I installed a late model jug with electric pump on it. It works so much nicer. I wired it to the factory switch also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Between Trucks...
Sounds like a great idea, any details on the install?
Beat it to fit, Paint it to match... ![]() |
yea, i picked a universal pump a few months ago from a flea market. It looks like it will work with my old pump, but i have t wire it to the old pump. which wires do i use? the pump has a 12v+ and a ground. the directions say to wire it to the 2 wire plug going into the old pump, but when i remove it, the windshield wipers dont work. there is also a single plug with a black wire and a 3 wire plug with a blue wire and 2 yellow wires. any help would be great!
Old member
Sorry,
wish I could help but it's been a long time ago since I wired it up I don't remember how and what color's.
