Relocate or trim the neutral switch?
The swap from a 4spd to auto is done, however the auto column (van/non-tilt)has the safety switch /brake pedal arm clearance problem.
Anybody have a more detailed description of the fixes.....I already screwed up and trimmed too much off the side of one switch after misreading an old post. thanks in advance, swdobbs...... |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
its all about the +6 inches
I did away with mine too...none of my trucks ever had a safety switch before, nor back up lights.
I'll probably address the problem at a later date...actually, i probably won't, but I like to think I will. |
What problem...I have a van tilt auto column that I would like to use the switch on...will it interfere with my brake pedal? I haven't installed the column yet.
69 SWB LT1/4L60E www.classicplace.com |
Yes, the switch will be in the way when you go to bolt it up. You need to move it lower on the column. I'm thinking (which means rough guess looking at fuzzy memorys in my head) about 6 inches south oughta do it.
