Just loves his truck.
Wheel Spacers
i got a set of muds for my truck and i dont want to shell out 200 dollars for a set of 6 lug 15" tires...so the next best thing i can do is get some 2" spacers...i was wondering if any one has had any "Bad" experances with them... i only need an 1" to clear them but they will rub when i turn so...any advice would help here...
o BTW there 31x10.5 and im only putting them on the back...so... im putting the simi-altrearns on the front.
![]() ![]() EAGLE SCOUT FTW!!! |
Re: Wheel Spacers
http://cgi.ebay.com/ebaymotors/WHEEL...spagenameZWDVW
those are what i am considering to get unless some one has some rims they want to sell with a 4in back spacing
Re: Wheel Spacers
sent you a pm
Re: Wheel Spacers
Stonewall the ones on Ebay all have 14mm studs our trucks use 7/16' studs. You would have to have new lug nuts for all 4 wheels and if you used just 2 spacers you would need different lugs front and rear.
I have been looking for a set of 6 lugs for my 4x4 for the rear but the ones on Ebay are 14mm. If any one knows where to get the proper ones chime in. Sorry don't mean to hijack or anything. Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Re: Wheel Spacers
what do you mean by 14mm...will they not fit? idk... i only need them for the back because i only have 2 muds...and thats where they are going.
o...im not doing a new build i just wanted to know if they fit.
![]() ![]() EAGLE SCOUT FTW!!! Last edited by stonewall618; 02-27-2008 at 06:31 PM. |
Re: Wheel Spacers
The diameterof the wheel stud on the Spacer is 14mm your studs on your axle should be 7/16". They will send you 14mm Lug nuts to install the spacer.
Ron
I have a radical idea!
Re: Wheel Spacers
All you have to do is install the spacers on the drum with stock 7/16 lug nuts, and use the 14mm nuts they send to bolt on the wheel. If you have chrome lug nuts, you will have to buy a set if you want to match the front but that's a not a big deal. That's what I did on my '69 C/10.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-28-2008 at 08:33 AM. |
Re: Wheel Spacers
Here is aplace you can special order for the 7/16' stud not too bad of price and Made in the USA. The ones on ebay are probaly good but I think I will go with the Wierd Harrolds.
Ron http://www.whcoolparts.com/new%20page0.htm
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson Last edited by Husker; 02-28-2008 at 08:48 AM. |
#9 | |
Re: Wheel Spacers
#10 | |
![]() Join Date: May 2006
Re: Wheel Spacers
chrome makes it go FASTER!
Re: Wheel Spacers
Any tire/rim shop should have these in stock. Plus they will be able to answer all ?? you have. I got mine from a small tire/custom rim shop. They were about the same price as Ebay, But I got a guarantee and a little free advice.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
Re: Wheel Spacers
not to sound like an a$$ hole...i have dont that...eather they dont have them or they want 300 dollars for a set... and if they dont have them there like 400 to get them ordered... they told me if i can get them they will put them on and i was like...ok...where do i get them.... they said...throu us...(...) i left and started doing research... so...ya.
