Old 02-28-2008, 08:31 AM   #1
Chevyman680063
Chevyman680063's Avatar
Front brake drums
I would like to know if anyone knows where you can buy front brake drums for a '68 C-10 with the center hub. Every brake drum I have seen does not have the center hub. Thanks in advance.
Chevyman680063 is offline   Reply With Quote
Old 02-28-2008, 10:25 AM   #2
Chevyman680063
Re: Front brake drums
No one knows?
Old 02-28-2008, 10:35 AM   #3
shifty
Questionable
shifty's Avatar
not sure if i follow what you're asking?
it sounds like you're asking about a spindle, but with a drum brake? but such a thing doesn't exist.
i'm in GA too, and selling a complete '68 front suspension if you're interested, with four american racing wheels and tires for $200, plus drum brakes, crossmember, control arms, springs, etc. all that other stuff is included (even new tie rods + sleeves and center link), got it listed in the classifieds if you want to look and see if it's what you need.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-28-2008, 10:40 AM   #4
Chevyman680063
I don't need the spindles, just the drums. The center hub is the piece that is riveted to the drum and the race where the wheel bearings go sits in the hub. Everywhere I've looked has only had just a drum.
Old 02-28-2008, 11:04 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Been a while since I had a 1/2 ton (like 12 years) but all I remember is the drum being one piece that just slid over the studs like in this pic;
opps; here; http://www.lmctruck.com/icatalog/cb/full.asp?page=144
Sorry if this isn't any help.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 02-28-2008, 11:09 AM   #6
El Jay
Gone to greener pastures
If memory serves, and I admit, it's been a long time, you have to grind off the rivets & reuse the hubs.
I could very well be wrong, so if I am, I hope somebody corrects me.
El Jay
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 02-28-2008, 06:35 PM   #7
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
You can get drums at the auto parts store, if they don't have them in stock, they can order them
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 02-28-2008, 07:09 PM   #8
68gmsee
Active Member
68gmsee's Avatar
This type of setup does not ring a bell with me either. I've got a 68 GMC and a 69 Chevy both with drums all around but they don't have a center hub. Are you sure it's not the spindle that you are needing.
A pic would help.
68gmsee is offline   Reply With Quote
Old 02-28-2008, 07:24 PM   #9
cdowns
cdowns's Avatar
from the factory the drums are riveted onto the hubs and the replacement drums have always been just the drum requireing the rivets to b ground off and resusing the original hubs//from new they have never been available as hub and drum in one piece
Old 02-28-2008, 07:39 PM   #10
Bus Ted Knuckle
Son of a gun
Chevyman, I see what you are saying now, downs has it right, you reuse your original hubs.
BEATERS ARE NEATER
Old 02-28-2008, 10:42 PM   #11
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by 68gmsee View Post
This type of setup does not ring a bell with me either. I've got a 68 GMC and a 69 Chevy both with drums all around but they don't have a center hub. Are you sure it's not the spindle that you are needing...
I meant "hub" not spindle on last sentence.
And now I do recall having to remove the rivets on the picture below when I first did a brake job on my 68 GMC... 15 years ago.. Memory ain't what it used to be.
Old 02-29-2008, 06:53 AM   #12
Chevyman680063
That's exactly what I was talking about. No one seems to sell the hubs though. My '68 was wrecked several years ago and plan on rebuilding it but I had to use one of the front drums on another truck because that truck had one front drum that the inside of the hub where the race goes was scarred up so the race would just spin around freely in the hub. I guess I will have to get one of those front disc conversion kits, probably will be easier in the long run with the disc anyway. One question, can I use the stock style master cylinder that came on my '68 and will I be able to leave it manual brakes or will I have to convert to power brakes too?
Old 02-29-2008, 08:02 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'd need to upgrade your master cylinder for disk/drum instead of drum/drum... you'd need the correct proportioning valve too. However, you don't need a booster. GM sold billions of disk brake vehicles wioth no booster.
Old 02-29-2008, 08:04 AM   #14
Chevyman680063
Thanks Longhorn Man, that's all I needed to know.
