Do the Dew!
Engine stand modification for storing your motor.
I can hope that this will help anyone out who may have faced a similar situation.
I needed to store a motor, I did not have an engine cradle. I mounted a 1974 Chevy 454 BB onto an engine stand that was rated at 1000 lbs. When I started to lower the engine into position the stand was starting to fold in. The mounting plate was starting to bend and the support beam was starting to lean forward. I decided to use a 6X6 post with a 2x10, and two 2x6s across the legs of the cherry picker to support the engine under the oil pan. But I did not like to support the weight of the engine on the oilpan. I was using my hoist to alleviate the weight. I had to do something quick. I came up with an idea that would fix my dilemna. I had the iron sitting around, so I commenced to take measurements and prepare the metal. I used 3/4" steel tubing, 2-pieces at 4 inches, 1-1/4" angle iron, 2-pieces at 5 inches, and two pieces at 24 inches. I welded the two 5 inch pieces of angle iron together to make a cradle to sit on the engine stand beam. I took a measurement to determine my motormount dimension, calculated the angle in degrees, then cut them at 22 degrees, and welded the two 24 inch angle irons to the cradle. I then trimmed out the other ends of the angle iron to fit the tubes and welded them into place. I prepped and primed the fabbed support and let sit to dry for a couple hours. I painted the support with three coats of Krylon enamel and let it sit to dry thoroughly. When the time was ready I installed the support to the motor mounts, then lowered the engine back onto the stand. I observed the reaction, and decided that it was going to work. I moved the engine hoist and pushed the engine stand to the corner of the garage. I was pleased with the end result. |
I am a Referee of life.
Re: Engine stand modification for storing your motor.
Looks like it worked like a charm.I would suggest you think about upgrading the casters on the engine stand.Big Blocks are heavy so if you are going to do very many you will need a higher rated and good quality engine stand.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Active Member
![]() Join Date: Jul 2007
Good improvisation and a good way to insure engine won't go anywhere.
knuckle buster..
![]() Join Date: Oct 2007
that looks great! i wish i had thought of that before my 396bb wooden cradle fell apart. i probably wouldn't have sold the rebuilt motor if i had something better.
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
its all about the +6 inches
a BBC doesn't weigh more than 1000 pounds. I know it is kinda freaky to see the stand flex like that, but it's designed to.
LAIDOUT
That is way way better than the old trailer tire I set my engine in for two years!
I would suggest a patent.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Do the Dew!
Thanks for the warm comments! I can only hope that it helps others out there. Space was limited in my garage.
I have the castors in the works, but in the meantime, I purchased a box of foundation plate washers, they measure 2"x2", 3/16" thick, (thicker than a standard 1/2" washer) and have a 1/2" hole punched. It helped reinforce the castors very well. Funnt thing, my wife also mentioned about a patent, this may be far fetched, but I am willing to produce them, for a small fee. ![]() Once again, thank you. |
reminds me of the time i built my first engine yrs ago.....super nice small block done with all the bells and whistles, i had it on a stand fully dressed, kissed it good night, shut the shop doors took two steps and heard a thud. i thought something fell off the wall, so i went to investigate and their she lie bust on the concrete.
![]() ![]() ![]() ![]() ![]() ![]() ![]() the stand i have now can hold a john deere tractor engine. ![]()
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 |
