Old 03-02-2008, 10:40 AM   #1
jwn1975
e-brake cable end?
I need to shorten my e-brake cable, where and how do i get another cable end? I dont want to use the "u" shaped nut and bolt thingey. Id like to crimp on another end. HELP!
BTW thanks again
jwn1975 is offline   Reply With Quote
Old 03-02-2008, 02:54 PM   #2
JimKshortstep4x4
Re: e-brake cable end?
I have not located any ends so I have been making my own out of 3/8 steel rod cut to length. Drill a through hole so that the cable just fits and then crimp the part onto the cable.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-02-2008, 10:42 PM   #3
TravisH
TravisH's Avatar
I never had the ebrake on my truck but couldn't you just trim from the other end?
Jims idea sounds good but you can also buy aluminum crimp fittings, would save some time
TravisH is offline   Reply With Quote
