400 trans kickdown
I am looking to see if anybody has a kick down for a 400 transmission? I was told that they were used starting in 1966 in the Chevy and GMC trucks and I am using one in my 67 but I need the electric kick down switch. Thanks
![]() Join Date: Apr 2005
Re: 400 trans kickdown
I've seen 67's with factory big blocks that had the 400 in them.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I hae one that is complete - wiring, kick down switch, and the tab that attaches to the carb. thottle arm. this is a nice part all in excellant shape/condition. I will take $75 shipped for the complete set if interested.
Do you have any pictures of the setup? I am putting this on a 90 TBI motor so I want to make sure it will work for me.
Pics of my 70 burb, not a great one. I can take one tomorrow if you want.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-03-2008 at 11:32 AM. |
Does the kick down mount under the hood? I have a 71 gas pedal with the kick down switch I was thinking of using but I then have to modify the firewall and the switch to use the cable instead of the rod.
It mounts under the hood.
If you use the 71 pedal you can still get switch from GM, but to my knowledge the wiring is not available. The switch for the 71 /72 mounts to the pedal bracket and all brackets have the prevision for the switch. If you use the rod type then the kick down switch that mounts to the carb is the type you need. My set up is at the garage and I will have to go get it in the morning.
